OneWire library affecting other pins on port
I've got an SPI device using some pins on the same port as a DS18S20.
Everything works fine until I try and obtain data from the OneWire sensor, as the OneWire::write function seems to send the whole port "floating" after the operation (not just the pin for the OneWire device).
I suspect it's these lines that are to blame in the write function of the library:
DIRECT_MODE_INPUT(baseReg, bitmask);
DIRECT_WRITE_LOW(baseReg, bitmask);
Where baseReg is the port that the pin resides.
I'm using Paul Stoffregen's v2.0 library.
Has anyone else experienced anything similar? I'm a bit short on pins so would prefer not to have to try and put the Dallas device on it's own port.
