Hello,
Let me preface this post with I’m a newbie and have limited programming background so please bare with me.
I have an Arduino uno with and ethernet sheild. I’m trying to get two temperature sensors to report to cosm. Over a year ago (prior to Cosm) I setup another identical setup using Pachube and its still functioning fine today. However using the same code does not work with the newly created FeedID. It gives me 403’s. I’m assuming its due to the new API version that must be required?
At any rate Cosm has example code they give and in trying to figure out how to get the example code to work for the new API I’m having all sorts of issues. It seems as though once I solve one compilation error another shows. Fun stuff However I’m now stumped and not sure how to proceed. Can you please help in identifying why I’m getting the following error when verifying the code?
‘class EthernetClient’ has no member named ‘print’
sketch_nov09b.cpp: In function ‘void sendData(int)’:
sketch_nov09b:114: error: ‘class EthernetClient’ has no member named ‘print’
sketch_nov09b:115: error: ‘class EthernetClient’ has no member named ‘print’
sketch_nov09b:116: error: ‘class EthernetClient’ has no member named ‘println’
sketch_nov09b:117: error: ‘class EthernetClient’ has no member named ‘println’
sketch_nov09b:118: error: ‘class EthernetClient’ has no member named ‘print’
sketch_nov09b:119: error: ‘class EthernetClient’ has no member named ‘println’
sketch_nov09b:120: error: ‘class EthernetClient’ has no member named ‘print’
sketch_nov09b:121: error: ‘class EthernetClient’ has no member named ‘println’
sketch_nov09b:122: error: ‘class EthernetClient’ has no member named ‘print’
sketch_nov09b:127: error: ‘class EthernetClient’ has no member named ‘println’
sketch_nov09b:130: error: ‘class EthernetClient’ has no member named ‘println’
sketch_nov09b:131: error: ‘class EthernetClient’ has no member named ‘println’
sketch_nov09b:132: error: ‘class EthernetClient’ has no member named ‘println’
sketch_nov09b:135: error: ‘class EthernetClient’ has no member named ‘print’
sketch_nov09b:136: error: ‘class EthernetClient’ has no member named ‘println’
The line of code that error is being generated on is - client.print(“PUT /v2/feeds/”);
Here is the current sketch
Pachube sensor client
This sketch connects an analog sensor to Pachube (http://www.pachube.com)
using a Wiznet Ethernet shield. You can use the Arduino Ethernet shield, or
the Adafruit Ethernet shield, either one will work, as long as it's got
a Wiznet Ethernet module on board.
This example has been updated to use version 2.0 of the Pachube.com API.
To make it work, create a feed with a datastream, and give it the ID
sensor1. Or change the code below to match your feed.
Circuit:
* Analog sensor attached to analog in 0
* Ethernet shield attached to pins 10, 11, 12, 13
created 15 March 2010
modified 9 Apr 2012
by Tom Igoe with input from Usman Haque and Joe Saavedra
http://arduino.cc/en/Tutorial/PachubeClient
This code is in the public domain.
#include
#include
#include
#include
#define APIKEY "YOUR API KEY GOES HERE" // replace your pachube api key here
#define FEEDID 00000 // replace your feed ID
#define USERAGENT "My Project" // user agent is the project name
// assign a MAC address for the ethernet controller.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
// fill in your address here:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0x95};
// fill in an available IP address on your network here,
// for manual configuration:
//IPAddress ip(192,168,168,25);
byte ip[] = {
192, 168, 168, 251 }; // no DHCP so we set our own IP address
// initialize the library instance:
EthernetClient client;
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
IPAddress server(216,52,233,122); // numeric IP for api.pachube.com
//char server[] = "api.pachube.com"; // name address for pachube API
unsigned long lastConnectionTime = 0; // last time you connected to the server, in milliseconds
boolean lastConnected = false; // state of the connection last time through the main loop
const unsigned long postingInterval = 10*1000; //delay between updates to Pachube.com
// while (!Serial) {
// ; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection:
//if (Ethernet.begin(mac) == 0) {
//Serial.println("Failed to configure Ethernet using DHCP");
// DHCP failed, so use a fixed IP address:
Ethernet.begin(mac, ip);
// read the analog sensor:
int sensorReading = analogRead(A0);
// if there's incoming data from the net connection.
// send it out the serial port. This is for debugging
// purposes only:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if there's no net connection, but there was one last time
// through the loop, then stop the client:
if (!client.connected() && lastConnected) {
Serial.println("disconnecting.");
client.stop();
// if you're not connected, and ten seconds have passed since
// your last connection, then connect again and send data:
if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {
sendData(sensorReading);
// store the state of the connection for next time through
// the loop:
lastConnected = client.connected();
// this method makes a HTTP connection to the server:
void sendData(int thisData) {
// if there's a successful connection:
if (client.connect(server, 80)) {
Serial.println("connecting...");
// send the HTTP PUT request:
client.print("PUT /v2/feeds/");
client.print(FEEDID);
client.println(".csv HTTP/1.1");
client.println("Host: api.pachube.com");
client.print("X-PachubeApiKey: ");
client.println(APIKEY);
client.print("User-Agent: ");
client.println(USERAGENT);
client.print("Content-Length: ");
// calculate the length of the sensor reading in bytes:
// 8 bytes for "sensor1," + number of digits of the data:
int thisLength = 8 + getLength(thisData);
client.println(thisLength);
// last pieces of the HTTP PUT request:
client.println("Content-Type: text/csv");
client.println("Connection: close");
client.println();
// here's the actual content of the PUT request:
client.print("sensor1,");
client.println(thisData);
else {
// if you couldn't make a connection:
Serial.println("connection failed");
client.stop();
// note the time that the connection was made or attempted:
lastConnectionTime = millis();
// This method calculates the number of digits in the
// sensor reading. Since each digit of the ASCII decimal
// representation is a byte, the number of digits equals
// the number of bytes:
int getLength(int someValue) {
// there's at least one byte:
int digits = 1;
// continually divide the value by ten,
// adding one to the digit count for each
// time you divide, until you're at 0:
int dividend = someValue /10;
while (dividend > 0) {
dividend = dividend /10;
digits++;
// return the number of digits:
return digits;
Please advise and thanks in advance.
Thanks,
Brad
