Hello,
I got a code to run 14 StepperMotors via AccelStepper libary.
But I want just to run 3 StepperMotors at the same time.
If 4 (ore more) StepperMotor should be used, then the 4th should wait until one of the other 3 has finished.
Means: Start a StepperMotor when a “free slot” is available.
How can i do this?
Here is my Code:
#include <Max3421e.h>
#include <Usb.h>
#include <AndroidAccessory.h>
#include <AccelStepper.h>
#define VALUE_OFF 0x0
#define VALUE_ON 0x1
#define COMMAND_DRINK 0x2
#define COMMAND_LED 0x3
AndroidAccessory acc("Manufacturer",
"Model",
"Description",
"1.0",
"http://nichtsda.com",
"0000000012345678");
//pin definitions. must be PWM-capable pins!
const int redPin = 2;
const int greenPin = 3;
const int bluePin = 4;
AccelStepper stepper1 (AccelStepper::DRIVER, 23, 12);
AccelStepper stepper2 (AccelStepper::DRIVER, 27, 11);
AccelStepper stepper3 (AccelStepper::DRIVER, 31, 11);
AccelStepper stepper4 (AccelStepper::DRIVER, 35, 11);
AccelStepper stepper5 (AccelStepper::DRIVER, 39, 11);
AccelStepper stepper6 (AccelStepper::DRIVER, 43, 11);
AccelStepper stepper7 (AccelStepper::DRIVER, 47, 11);
AccelStepper stepper8 (AccelStepper::DRIVER, 51, 11);
AccelStepper stepper9 (AccelStepper::DRIVER, 24, 11);
AccelStepper stepper10 (AccelStepper::DRIVER, 28, 11);
AccelStepper stepper11 (AccelStepper::DRIVER, 32, 11);
AccelStepper stepper12 (AccelStepper::DRIVER, 36, 11);
AccelStepper stepper13 (AccelStepper::DRIVER, 40, 11);
AccelStepper stepper14 (AccelStepper::DRIVER, 44, 11);
//int stepPin[16]={23,27,31,35,39,43,47,51,24,28,32,36,40,44,48,52};
int multiplikator = 60000;
int MengeZutat[16];
//maximum duty cycle to be used on each led for color balancing.
//if "white" (R=255, G=255, B=255) doesn't look white, reduce the red, green, or blue max value.
const int max_red = 255;
const int max_green = 255;
const int max_blue = 200;
byte colors[3] = {0, 0, 0}; //array to store led brightness values
byte rcvmsg[16];
//set all three of our led pins to output
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
acc.powerOn();
stepper1.setMaxSpeed(1800.0);
stepper1.setAcceleration(1000.0);
stepper2.setMaxSpeed(1100.0);
stepper2.setAcceleration(1000.0);
stepper3.setMaxSpeed(1800.0);
stepper3.setAcceleration(1000.0);
stepper4.setMaxSpeed(1800.0);
stepper4.setAcceleration(1000.0);
stepper5.setMaxSpeed(1800.0);
stepper5.setAcceleration(1000.0);
stepper6.setMaxSpeed(1800.0);
stepper6.setAcceleration(1000.0);
stepper7.setMaxSpeed(1800.0);
stepper7.setAcceleration(1000.0);
stepper8.setMaxSpeed(1800.0);
stepper8.setAcceleration(1000.0);
stepper9.setMaxSpeed(1800.0);
stepper9.setAcceleration(1000.0);
stepper10.setMaxSpeed(1800.0);
stepper10.setAcceleration(1000.0);
stepper11.setMaxSpeed(1800.0);
stepper11.setAcceleration(1000.0);
stepper12.setMaxSpeed(1800.0);
stepper12.setAcceleration(1000.0);
stepper13.setMaxSpeed(1800.0);
stepper13.setAcceleration(1000.0);
stepper14.setMaxSpeed(1800.0);
stepper14.setAcceleration(1000.0);
if (acc.isConnected()) {
acc.read(rcvmsg, sizeof(rcvmsg), 1);
if (rcvmsg[14] == COMMAND_LED ) {
byte value = rcvmsg[15];
if (value == VALUE_ON) {
colors[0] = rcvmsg[0] + 128;
colors[1] = rcvmsg[1] + 128;
colors[2] = rcvmsg[2] + 128;
analogWrite(redPin, map(colors[0], 0, 255, 0, max_red));
analogWrite(greenPin, map(colors[1], 0, 255, 0, max_green));
analogWrite(bluePin, map(colors[2], 0, 255, 0, max_blue));
else if (value = VALUE_OFF) {
colors[0] = 0;
colors[1] = 0;
colors[2] = 0;
if (rcvmsg[14] == COMMAND_DRINK ) {
//int sleepPin[16]={25,29,33,37,41,45,49,53,22,26,30,34,38,42,46,50};
stepper1.move(rcvmsg[0]*multiplikator);
stepper1.setEnablePin(25);
stepper2.move(rcvmsg[1]*multiplikator);
stepper2.setEnablePin(29);
stepper3.move(rcvmsg[2]*multiplikator);
stepper3.setEnablePin(33);
stepper4.move(rcvmsg[3]*multiplikator);
stepper4.setEnablePin(25);
stepper5.move(rcvmsg[4]*multiplikator);
stepper5.setEnablePin(37);
stepper6.move(rcvmsg[5]*multiplikator);
stepper6.setEnablePin(41);
stepper7.move(rcvmsg[6]*multiplikator);
stepper7.setEnablePin(45);
stepper8.move(rcvmsg[7]*multiplikator);
stepper8.setEnablePin(49);
stepper9.move(rcvmsg[8]*multiplikator);
stepper9.setEnablePin(53);
stepper10.move(rcvmsg[9]*multiplikator);
stepper10.setEnablePin(22);
stepper11.move(rcvmsg[10]*multiplikator);
stepper11.setEnablePin(26);
stepper12.move(rcvmsg[11]*multiplikator);
stepper12.setEnablePin(30);
stepper13.move(rcvmsg[12]*multiplikator);
stepper13.setEnablePin(34);
stepper14.move(rcvmsg[13]*multiplikator);
stepper14.setEnablePin(38);
else if (value == VALUE_OFF ) {
stepper1.run();
if (stepper1.isRunning() == false) {
stepper1.disableOutputs();
stepper2.run();
if (stepper2.isRunning() == false) {
stepper2.disableOutputs();
stepper3.run();
if (stepper3.isRunning() == false) {
stepper3.disableOutputs();
stepper4.run();
if (stepper4.isRunning() == false) {
stepper4.disableOutputs();
stepper5.run();
if (stepper5.isRunning() == false) {
stepper5.disableOutputs();
stepper6.run();
if (stepper6.isRunning() == false) {
stepper6.disableOutputs();
stepper7.run();
if (stepper7.isRunning() == false) {
stepper7.disableOutputs();
stepper8.run();
if (stepper8.isRunning() == false) {
stepper8.disableOutputs();
stepper9.run();
if (stepper9.isRunning() == false) {
stepper9.disableOutputs();
stepper10.run();
if (stepper10.isRunning() == false) {
stepper10.disableOutputs();
stepper11.run();
if (stepper11.isRunning() == false) {
stepper11.disableOutputs();
stepper12.run();
if (stepper12.isRunning() == false) {
stepper12.disableOutputs();
stepper13.run();
if (stepper13.isRunning() == false) {
stepper13.disableOutputs();
stepper14.run();
if (stepper14.isRunning() == false) {
stepper14.disableOutputs();
