Only getting 2 volts from output pins
Hello,
When sending a digitalWrite high to any output pins, I am only getting about 2 volts. I have a good 5 and 9 volts at their respective pins. I am running an Uno with an Ethernet shield.
Any ideas?
Any ideas?
Post code. Post a schematic. Post your method.
Any ideas?
You forgot to define the pins as outputs in the setup() function.
missing a common ground?
