Thanks PaulS! I’ll work on it.
GoForSmoke:
You need to use the Autoformat tool in your IDE and you need to post the whole sketch.
Here’s the whole sketch for any further suggestions:
#include <BLIP_LEDS_SPI_LPD6803.h>
#define NUM_LEDS 24
// Set the number of LEDs in use here
int state = 0;
BL.setLeds(NUM_LEDS); // Initialisation functions
BL.init(); // SPI interrupt will now send out data to LEDs. This happens in the background, pretty fast.
// If you arrange your LEDs in a grid, you must define the grid size here.
//Assume LEDS are layed out in a zig zag manner eg for a 5x5 (viewed from front):
//0 9 10 19 20
//1 8 11 18 21
//2 7 12 17 22
//3 6 13 16 23
//4 5 14 15 24
BL.gridHeight=5; // Grid dimensions for LINE and BOX effect functions are defined here. Also used for Spectrum Analyzer function.
BL.gridWidth=5;
// Set all the LEDs to black (off)
BL.setRange(0, NUM_LEDS, BL.color(0,0,0));
BL.show();
unsigned int Counter, Counter2, Counter3;
//BL.color returns a 16bit number with the colors for red,green and blue all represented as 5 bit numbers
//Values for r,g,b can be 0 to 31 (thats a 5 bit number!)
//Note that the order that you pass the red, green and blue parameters depends on how the LEDs are physically connected to the
//pins on the controller chip. This varies with different revisions of the pixels, so you need to check this with your own
//pixels and change the code accordingly. support@bliptronics.com
//Set LEDs 0 to 4 as blue.
if (Serial.available()){
int characterRead = Serial.read();
if (characterRead == 'a') {
state++;
if (state==14) {
state=0;
if (state==1) {
//fadeinfadeout
for (int i=0;i<31;i+=5) {
for (int j=0;j<NUM_LEDS;j++) {
BL.setPixel(j,i,0,0);
BL.show();
delay(5);
for (int i=31;i>0;i-=5) {
BL.show();
delay(5);
blank();
else if (state==2){
for(int i=0;i<20;i++) // Strobe Effect
strobe(30);
blank();
else if (state==3){
for (int i=0;i<150;i++){
BL.setPixel(random(0,NUM_LEDS),0,31,0);
BL.show();
delay(15);
blank();
BL.setRange(0,NUM_LEDS,BL.color(0,0,0));
BL.show();
else if (state==4){
for(Counter=0;Counter < 5;Counter++) // Color Wipe Effect
ColorUp(BL.color(random(0,32),random(0,32),random(0,32)));
delay(100);
blank();
else if (state==5){
for (int i=0;i<5;i++) {
for(Counter=0; Counter < 96 ; Counter++) // Color Wheel Effect
for(Counter2=0; Counter2 < NUM_LEDS; Counter2++)
BL.setPixel(Counter2, BL.Wheel((Counter)%96));
Counter3+=(96 / NUM_LEDS);
BL.show();
delay(25);
blank();
else if(state==6){
BL.setPixel(random(0,NUM_LEDS),31,0,0);
BL.show();
delay(30);
blank();
else if(state==7){
for(Counter=0; Counter < 96 ; Counter++) // Scrolling Rainbow Effect
BL.setPixel(Counter2, BL.Wheel((Counter2*2 + Counter)%96));
BL.show();
delay(25);
blank();
else if(state==8){
BL.setRange(0,NUM_LEDS,BL.color(31,0,31));
BL.show();
delay(50);
else if(state==9){
BL.setRange(0,NUM_LEDS,BL.color(31,31,0));
BL.show();
delay(50);
else if(state==10){
BL.setRange(0,NUM_LEDS,BL.color(0,31,31));
BL.show();
delay(50);
else if(state==11){
BL.setRange(0,NUM_LEDS,BL.color(31,0,0));
BL.show();
delay(50);
blank();
else if(state==12){
BL.setRange(0,NUM_LEDS,BL.color(0,31,0));
BL.show();
delay(50);
blank();
else if(state==13){
BL.setRange(0,NUM_LEDS,BL.color(0,0,31));
BL.show();
delay(50);
blank();
else if(state==14){
ON_Fade();
blank();
else{
blank();
void blank()
BL.show();
void ColorUp( unsigned int ColorToUse)
byte Counter;
for(Counter=0;Counter < NUM_LEDS; Counter++)
BL.setPixel(Counter, ColorToUse);
BL.show();
delay(25);
void ON_Fade ()
byte Counter;
unsigned int a=0xff,b=0xff,c=0xff;
BL.setPixel(Counter,BL.color(31,31,31));
BL.show();
delay(10);
for(int i = 0; i<31;i++)
BL.setPixel(Counter,BL.color(a,b,c));
BL.show();
delay(10);
a--;
b--;
c--;
void strobe(int flash_rate)
for(int i=0;i < NUM_LEDS; i++)
BL.setPixel(i,BL.color(31,31,31));
BL.show();
delay(flash_rate);
BL.setRange(0, NUM_LEDS-1, BL.color(0,0,0));
BL.show();
delay(flash_rate);
