OO arduino create instance of a class inside a class
Hi I was just wondering in arduino land how you create an instance if a class inside a class?
I have a class that inherits from stepper and inside it I'd like it to be responsible for creating an instance and holding a reference to an instance of another custom class as well as some inbuilt library classes..
Does anyone have a decent tutorial on doing this? I come from Java land
Like you declare any other variable... Nothing special about classes.
Thomen:
You want to learn about inheritance, or how to create an object in a class?
If your class member object touches hardware, just be sure to create an initializing member function to call in setup() (or run time instantiation) to do that work(i.e. Serial.begin()).
BulldogLowell:
That is ONLY needed if you're creating a global instance of the class...
Regards,
Ray L.
RayLivingston:
Regards,
Ray L.
thus the the:
BulldogLowell:
COMPLETELY unnecessary for run-time instantiation. The class constructor is all that's needed.
Regards,
Ray L.
RayLivingston:
Regards,
Ray L.
Not necessarily... what if your class Constructor hasn't initialized the hardware?
Setting pinMode() would be a nice little example.
Look at the Servo library...
Not trying to be argumentative but I'm right(er). :wink:
