Op amp Am FM Radio
Does anyone know of a website that has instructions on how to build an AM/FM operational amplifier circuit with an explanation of the circuit?
Thanks
Rico Bravo
Sorry that phrase is meaningless. An operational amplifier is not AM or FM as these are modulation methods.
Do you mean an AM/FM radio?
http://www.national.com/pf/LM/LMX3162.html
Ok, say it another way. I would like to build a simple AM/FM Receiver from a 741 Op Amp(s) to drive a little 8 ohm speaker.
Thanks
Rico Bravo
AM seems feasible (simple tuning and a diode for demodulation), but FM normally uses a phase-locked loop to perform the demodulation.
Ok, Where is the circuit??
Bolting an op-amp onto the tail-end of a simple AM crystal radio (is the ZN414 still available?) to provide a bit of audio gain wouldn't be too difficult, but then reconfiguring the op-amp as a PLL is a whole different ballgame.
Have a google for "op-amp", "FM" and "PLL" "
Apart from the fact that this is nothing to do with an arduino then you can't do this with a 741.
  1. A 741 frequency response will no go high enough to handle medium wave signals (500KHz to 12.MHz).
  2. A 741 has not got enough output power to handle driving an 8 ohm speaker.
  3. A 741 frequency response will no go high enough to handle VHF wave signals (89 MHz to 104 MHz)
HA,
Found it!!
