Op Amp Hilarity
http://www.micrel.com/_PDF/mic6211.pdf
Take a look at the trademarked name. :smiley: LMAO
Jiggy-Ninja:
And they color them pink. This is all to appeal to the female engineers. :smiley:
Now if only they could get the input offset voltage down so its itty-bitty too,
it would be a reasonable part.
Although its lower bandwidth, I've used the MCP6061 before, same package,
150uV worst case offset voltage (not 7mV!), fully rail-to-rail on input and output,
micropower (0.06mA quiescent), will run from 1.8V even!!
And then there is (or rather, was)
[quote author=Jack Christensen link=topic=260460.msg1839217#msg1839217 date=1407803733]
And then there is (or rather, was)[/quote]Have they been superceeded by the F&*%|^!' Fast version? :smiley:
I wonder if Bob Widlar had something to do with that product or datasheet. It has his fingerprints on it…
Henry_Best:
[/quote]
According to DigiKey's parametric search, the fastest op amp now is the ADL5565 at 11000V/us, which is not a whole lot better than this part. AD describes it more soberly: "The ADL5565 is a high performance differential amplifier optimized for RF and IF applications."
Henry_Best:
Off topic: It's supersede, not superceed!, from the latin verb "sedere" to sit - literally to sit on top of. Once you know that its hard to spell wrong!
Isn't it cute, and it has its own little applications page. awwwww ya got to love it.
You wonder why they bothered even making it in SMD package.
Tom....... :slight_smile:
