Never used one before ever, always stuck to transistors to do most jobs.
Am i right in assuming this circuit will indeed amplify an audio signal?
Only if you have a split supply. That is one with a positive voltage, a ground and a negative voltage.
For audio it is normal to couple through capacitors to remove any DC bias.
about 4 years ago (i know i know) I bought an what I thought was a 8 pin dip, Audio Amplifier, when i got home and looked it up..
it was a "LM833N Dual Audio Operational Amplifier"
and that's what that circuit uses uses (above picture) so I need a 2nd voltage rail? to pull off an audio amplifier?
cjdelphi:
about 4 years ago (i know i know) I bought an what I thought was a 8 pin dip, Audio Amplifier, when i got home and looked it up..it was a "LM833N Dual Audio Operational Amplifier"
Or as GM stated, instead of dual rail power you can use series capacitors coupling on the input and output of the op-amp. How much voltage or power are you expecting to get out of the op-amp. They are usually only good for preamp type audio applications, not for directly driving speakers.
Lefty
A preamp would be more useful as I can read in the signal to Arduino or to a power transistor to drive a speaker.
it's 1am here, just something i had in mind to do tomorrow (at last lol)
but yeah using a cap to block DC is a lot easier - i'll give it a go, i only have 1 of these IC's anyway it's just been gathering dust.
Look at this:-
http://interface.khm.de/index.php/labor/experimente/arduino-realtime-audio-processing/
It shows you how to bias an input with capacitors for feeding into an arduino.
