To start with, the AD620 needs a resistor across pins 1 and 8. This resistor controls the gain of that stage. Look at the datasheet for information on how to calculate this resistor.
Do you mean invert rather than convert? i.e. reflect the voltage about mid-rail?
What is the source impedance? If low then a simple unity gain inverting stage with 2.5V at the + input
would work. You'd need a genuine rail-to-rail opamp.
ardunio and mcp4725 dac output 0 to 5v
I want opamp output 5v to 0v
Inverting the direction of voltage doesn’t require an opamp, it just involves subtraction. If you’re sending 12 bits to the mcp4725, (4095 - count) will flip 0->5 to 5->0.
#include<Wire.h> //Include Wire library for using I2C functions
#define MCP4725 0x61 //MCP4725 address as 0x61 Change yours accordingly
unsigned int adc;
byte buffer[3];
Wire.begin(); //Begins the I2C communication
buffer[0] = 0b01000000; //Sets the buffer0 with control byte (010-Sets in Write mode)
adc = analogRead(A0) * 4; //Read Analog value from pin A0 and convert into digital (0-1023) multiply with 4 gives (0-4096)
float ipvolt = (5.0/4096.0)* adc; //Finding voltage formula (A0)
buffer[1] = adc >> 4; //Puts the most significant bit values
buffer[2] = adc << 4; //Puts the Least significant bit values
unsigned int analogread = analogRead(A1)*4 ; //Reads analog voltage from A1
float opvolt = (5.0/4096.0)* analogread; //Finding Voltage Formula (A1)
Wire.beginTransmission(MCP4725); //Joins I2C bus with MCP4725 with 0x61 address
Wire.write(buffer[0]); //Sends the control byte to I2C
Wire.write(buffer[1]); //Sends the MSB to I2C
Wire.write(buffer[2]); //Sends the LSB to I2C
Wire.endTransmission(); //Ends the transmission
hi
I'm trying with these codes
unfortunately 0 to 5v
about codes
I did not succeed
change you can suggest
Do you have a code
Not sure what you're trying to do with that opamp and it's output,
but I'm sure you don't need it to invert 0-5volt to 5-0volt.
Do it in code (see post#5).
Example sketch attached.
Leo..
int adc; // holds A/D readings
float ipvolt; // whatever that is
adc = 0; // reset with every loop
for (int i = 0; i < 4; i++) adc += analogRead(A0); // add four 10-bit readings | adc is now 0-4095
// convert to volt, assuming VCC is 5.0volt (which it rarely is)
ipvolt = (5.0 / 4096.0) * adc; // 0-5volt
// or... invert and convert to volt
ipvolt = (5.0 / 4096.0) * (4095 - adc); // 5-0volt
Wawa:
Leo..
for (int i = 0; i <4; i ++) adc + = analogRead (A0);
these codes are counted automatically and become 4095
I tried this code
analogread (A0); works independently of the input 4095 counter
// or ... turn it over and convert it to volts
I will try the code and I hope it works and thank you very much for your help.
god bless you and all of you from dangers
What I sent was pseudo code.
Before we even go there you need disclose what the status of your project is,
You have too much going on.
You need to eliminate all of the code in your sketch and simply do nothing but
command the dac to 5 different values and read back that you receive those
values. Nothing more.
There is nothing in the following code that is related to the problem you describe
except for the MCP4725 I2C code. You need to test the DAC BY ITSELF WITH NO OTHER
DEVICES FIRST.
IF AND ONLY IF , you can repeated command the DAC to 5 different voltages and read those
back with the arduino analog pin, then we can proceed. Otherwise, you're just spinning
your wheels.
There is one other thing that needs to be verified and that's the I2C addresses. Have you
run the I2C SCANNER yet ? If not , the code is attached and I will paste it in the post
window as well. Once you have verified the DAC works, AND verified there are no conflicting
addresses, then we can talk about your problem:
For starters, if you're using an MCP4725, why aren't you including an MCP4725 Library ?
unsigned int adc;
byte buffer[3];
I2C SCANNER CODE
// i2c_scanner
// Version 1
// This program (or code that looks like it)
// can be found in many places.
// For example on the Arduino.cc forum.
// The original author is not know.
// Version 2, Juni 2012, Using Arduino 1.0.1
// Adapted to be as simple as possible by Arduino.cc user Krodal
// Version 3, Feb 26 2013
// V3 by louarnold
// Version 4, March 3, 2013, Using Arduino 1.0.3
// by Arduino.cc user Krodal.
// Changes by louarnold removed.
// Scanning addresses changed from 0...127 to 1...119,
// according to the i2c scanner by Nick Gammon
// https://www.gammon.com.au/forum/?id=10896
// Version 5, March 28, 2013
// As version 4, but address scans now to 127.
// A sensor seems to use address 120.
// Version 6, November 27, 2015.
// Added waiting for the Leonardo serial communication.
// This sketch tests the standard 7-bit addresses
// Devices with higher bit address might not be seen properly.
#include <Wire.h>
Wire.begin();
while (!Serial); // Leonardo: wait for serial monitor
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknown error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
Serial.println("done\n");
delay(5000); // wait 5 seconds for next scan
