I'm trying to amplify a signal from a high impedance source (MCP4725, Sparkfun)
I need to find an buffer opamp that will be able to drive a 50 Ohm input impedance load.
Most opamps I've seen so far only drive a couple miliamps at most. To obtain the fullscale voltage range (0-5V), by Ohm's law V=IR I'd need something that is able to output 100mA. (Unless I am confused?)
If you guys could suggest opamps or workarounds I'd appreciate it!
The Analog Devices AD8531 is rated for 250mA output, is rail-to-rail input/output at 5V, and has a slew rate of 5V/us, 10 times higher than that of your DAC, so it should do the job. Input offset voltage is a bit high (25mV) but I’m not sure if that’s an issue for your application. It’s <$1 so not a bad place to start.
The Flexible MIDI Shield: MIDI IN/OUT, stacking headers, your choice of I/O pins
