i follow attached schematic, but i change the op-amp to AD620 and the input voltage is 2 volts before voltage divider (r1 and r2)..hence input to opamp is 0.5 volts ideally
i was expecting output is the same as the input..but no matter how i change the input, i always lost 0.5-0.6 v on the output, do you have any idea why?
That is a 2:1 divider on the input so for 2v before the divider, you should have 1v at the summing point between the two resistors which should match the output from the buffer (op-amp). (this is assuming the input to the buffer is within the range of the op-amp - above the negative side and below the positive side.
gpsmikey:
giri_ginanjar:
The AD620 is not rail-to-rail, you must provide a separate negative supply if using signals near 0V.
