Hi folks,
I need some hints here. I try to make a system where a relay open when i put a 12v bulb in a socket at the end of my circuit. I can only use the red wire (+) to do it. So i thought i could use an arduino with an ACS712 module to do it. Is it possible?
Your title says 3 bulbs, do you want the relay to activate when 1 bulb is plugged or all 3 or? Do you have a relay module or stand alone relay? Post links to all components. When you say "open" do you mean turn the relay ON or OFF?
