Hello everybody,
I have an arduino uno and MricoSD car reader, I´m dattalogging 3 one wire DS18B20 on a 8GB micro sd.
All works perfect: the .txt creates Ok if it doesn´t exist, open .txt Ok, and write it Ok.
I included a led and routine in diferents parts of code to show any error but if I extract the microSD while sketch is running it continues logging and gives no error. If I introduce microSD again it continues logging but write nothing on microSD.
This is my code:
#include <OneWire.h>
#include <SD.h>
File SDRegTemp;
OneWire onewire(7);
#define StatusLed 6
float TEMP[4];
byte e = 0;
byte l = 0;
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius;
void setup(void) {
pinMode(StatusLed, OUTPUT);
digitalWrite(StatusLed, LOW);
Serial.print("Iniciando SD ...");
if (!SD.begin(4)) {
error();
digitalWrite(StatusLed, HIGH);
if (SD.exists("RegTemp.txt")) {
return;
delay(200);
SDRegTemp = SD.open("RegTemp.txt", FILE_WRITE);
SDRegTemp.close();
void loop(void) {
while (e < 4) {
regtemp();
delay(6000);
e = 0;
void regtemp() {
if ( !onewire.search(addr)) {
onewire.reset_search();
e = 4;
return;
if (OneWire::crc8(addr, 7) != addr[7]) {
error();
onewire.reset();
onewire.select(addr);
onewire.write(0x44, 1);
present = onewire.reset();
onewire.write(0xBE);
for ( i = 0; i < 9; i++) {
data = onewire.read();
- int16_t raw = (data[1] << 8) | data[0];*
- if (type_s) {*
- raw = raw << 3; // 9 bit resolution default*
- if (data[7] == 0x10) {*
- raw = (raw & 0xFFF0) + 12 - data[6];*
- } else {*
- byte cfg = (data[4] & 0x60);*
- if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms*
- else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms*
- else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms*
- celsius = (float)raw / 16.0;*
- Serial.print("Temperature = ");*
- Serial.print(celsius);*
- Serial.print("ºC");*
- Serial.println();*
- TEMP[e] = celsius;*
- Serial.println(TEMP[e]);*
- if (SD.exists("RegTemp.txt")) {*
- Serial.println("existe");*
- return;*
- } else {*
- error();*
- SDRegTemp = SD.open("RegTemp.txt", FILE_WRITE); //abrimos el archivo*
- if (SDRegTemp) {*
- SDRegTemp.print("Sonda");*
- SDRegTemp.print(e);*
- SDRegTemp.print(", ");*
- SDRegTemp.print(TEMP[e]);*
- SDRegTemp.print("\n");*
- SDRegTemp.close();*
- } else {*
- Serial.println("error");*
- error();*
- e++;*
- if (e == 3) {*
- e = 0;*
void error() { - while (true) {*
- digitalWrite(StatusLed, HIGH);*
- delay(100);*
- digitalWrite(StatusLed, LOW);*
- delay(100);*
--- - if (SD.exists("RegTemp.txt")) {*
- return;*
- } else {*
- error();*
This function print "existe" when the microSD card is out of reader.
Any idea? Thanks.
