Greetings,
Is there a way to have a open circuit on an output pin.
I am using the Arduino mega output pin to switch a Leo bodnar BBI32 controller card what uses the negative from the mega to operate the controller card digitalwrite LOW
Is there a way to switch the pin so it not out putting a negative or 5v, I need it volt free
The same as a relay when it is normally open
Thanks in advance
Laurence
As long as the pin will not see <-0.5V or >5.5V you could try setting the pin to INPUT with a pinMode function. Inputs are hi-z (>10 MOhm). Then change back to OUTPUT when required.
DigitalWrite() does not make a negative, just near 0V. Not sure that I understand your problem so not really sure that the solution is the above. May be an XY problem.
Thank you
And apologies for posting in the wrong section
2020laurence:
Greetings,
Have you actually tested your Mega to see what happens? on my Uno board I get 0 volts from the output when it is LOW and 4.97 volts when HIGH
// set pin numbers
const int intled = 13;
const int out_test = 8;
pinMode(intled, OUTPUT);
pinMode (out_test, OUTPUT);
digitalWrite(intled, LOW);
digitalWrite(out_test, HIGH);
delay (2000);
digitalWrite(intled, HIGH);
digitalWrite(out_test, LOW);
delay(2000);
No. That is called an open collector output and the Arduino does not have them.
However, a simple NPN transistor with emitter to ground, and base connected to an input through a 1K resistor will produce such an output on the transistor's collector
