[Open log] How can I know the version of my Openlog
Dear,
I am tryinf to find the version of my OpenLog but I cna not
I read, I need to ender '?' at command mode, then I tried this without success.
  Serial.println(F("Begin"));
  pinMode(4,OUTPUT);       // Reset OpenLog
  uint8_t answer = 0;
  unsigned int timeout = 3000;
  unsigned long previous;
  previous = millis();
  Serial.println(F("Rest"));
      // Rest OpenLog
  digitalWrite(4, LOW);
  delay(100);
  digitalWrite(4, HIGH);
  // Wait for OpenLog to indicate file is open and ready for writing
  do{
    if(Serial.available())
      if(Serial.read() == '<')
        answer = 1;
   }while((answer <= 0) && ((millis() - previous) < timeout));
   Serial.write(26);
   Serial.write(26);
   Serial.write(26);
   //Serial.println(F("Command mode"));
   bool ok = false;
   while(!ok)
       if(Serial.read() == '>')
         ok = true;
   //Serial.println(F("Help"));
   Serial.print("append TEXT.TXT");
   Serial.write(13);
   while(1) {
      if(Serial.read() == '<') break;
  Serial.print("toto");
  Serial.write(13);
   Serial.write(26);
   Serial.write(26);
   Serial.write(26);
   ok = false;
   while(!ok)
         ok = true;
   Serial.print("?");
   Serial.write(13);
I can not see anythin about card
My config file is
9600,26,3,0,1,1,0
baud,escape,esc#,mode,verb,echo,ignoreRX
Someone know how to do that simple task?
Thank a lot
The list of commands says "Tip: Once you're in command mode the list of available commands can be brought up by typing ?." That doesn't sound like it displays the version number.
If you need to know the version you could always burn a known version of the firmware.
