open NUL: The system cannot find the file specified.
Hey,
I've just installed the arduino ide and I'm getting the error:
it happens when compiling for any board, with any example/written code.
What I've tried:
  • reinstalling the ide
  • setting file/folder permission for every location I could find a reference off
  • rebooting my pc
help will be very much appreciated
Full error log:
Arduino: 1.6.12 (Windows 10), TD: 1.31, Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Rodi\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10612 -build-path C:\Users\Rodi\AppData\Local\Temp\arduino_build_981473 -warnings=all -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Rodi\Documents\Arduino\octocontroller\octocontroller.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Rodi\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10612 -build-path C:\Users\Rodi\AppData\Local\Temp\arduino_build_981473 -warnings=all -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Rodi\Documents\Arduino\octocontroller\octocontroller.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Build options changed, rebuilding all
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Rodi\AppData\Local\Temp\arduino_build_981473\sketch\octocontroller.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Rodi\AppData\Local\Temp\arduino_build_981473\sketch\octocontroller.ino.cpp" -o "C:\Users\Rodi\AppData\Local\Temp\arduino_build_981473\preproc\ctags_target_for_gcc_minus_e.cpp"
Error compiling for board Arduino/Genuino Uno.
Is there a particular reason you're using Teensyduino?
pert:
Yes, I'm also in the possesion of a Teensy 2.0 board
Good day,
I have the same problem mentioned above. Even with sketch which was ok a month ago.
(I use 1.6.12)
Have you find the solution?
elektroby:
Good day,
(I use 1.6.12)
Sorry for the late respons, I managed to work around it by using the visual studio plugin for arduino and I believe I turned off a certain feature(I can't for the life of me remember what feature).
