open smart LGPD4524
i have a small problem with this tft display when i connect it up to my arduino nano i get a white screen, but when i reset the arduino it shows the display as it should untill i let go of the reset button then it goes back to a white screen
the pinout of the screen is
// GND -- GND
// 3V3 -- 3.3V
// CS -- A3
// RS -- A2
// WR -- A1
// RD -- 3.3V
// RST -- A0
// LED -- GND
// DB0 -- 8
// DB1 -- 9
// DB2 -- 10
// DB3 -- 11
// DB4 -- 4
// DB5 -- 13
// DB6 -- 6
// DB7 -- 7
any ideas on why this is doing this?
Open-Smart appear to have a 220x176 shield with RM68130. I can not find LGDP4524. But it is probably similar.
I would expect to see LCD_RD on A0. And there to be no LCD_RST pin. The other boards use a MAX809R Reset controller.
If you have bought a shield, why not buy a proper Uno to mate it with?
Please post a link to what you have actually bought.
And a link to whatever hack they have done to my library.
If you are prepared to test, I will add LGDP4524 to the proper MCUFRIEND_kbv library.
David.
here's a link to what i have bought. Theres also a link for the drivers on the page.
I have got an arduino mega 2560 but cant get that to work with the screen. i also have an uno on order.
They are evil b*stards. Open-Smart clearly say that it is a 3.3V display. DX.com leave it to the small print.
  • Compatibility: Because the logic level is 3.3V, it is compatible with 3.3V Arduino board, you generally need to add a level conversion circuit if you use a 5V Arduino Board (Arduino UNO R3 / Arduino Mega2560 / Arduino Leonardo).
You will damage the screen if you use 5V logic.
Adding level-shifters or resistors to a parallel display is more trouble than it is worth.
I have the equivalent 176x220 3.3V display with ILI9225 controller.
It works fine with 3.3V logic (and official MCUFRIEND_kbv)
Open-Smart and other Chinese companies sell Uno clones with switchable 3.3V / 5V logic.
Life is so much easier when you have 3.3V logic. And yes, they run fine @ 16MHz.
David.
