Open Sound Control Port on Arduino
I am looking to use OSC between my Arduino and Desktop.
I am looking to use this library: deadpixel » Arduino OSC
I am having trouble getting off of the ground. How to I specify which port I am going to use?
I only see this with the Ethernet version. Am I missing something?
Here is the code:
// MESSAGE PROTOCOL OBJECT
#include <OscSerial.h>
// tile support libraries
#include <EthernetUdp.h>
#include <SPI.h>
OscSerial oscSerial;
long timer;
  oscSerial.begin(Serial);
  pinMode(13, OUTPUT);
  // send a message every 100 ms
  // avoid using delay() since it just blocks everything
  long now = millis();
  if (now-timer > 100) {
    OscMessage msg("/helloFromArduino");
    msg.add(0); // <-- this could be any data
    oscSerial.send(msg);
    timer = now;
  // important!
  oscSerial.listen();
void oscEvent(OscMessage &m) { // *note the & before msg
  // receive a message
  m.plug("/led", myFunction);
void myFunction(OscMessage &m) {  // *note the & before msg
  // getting to the message data
  int value = m.getInt(0);
  if (value == 0) digitalWrite(13, LOW);
  if (value == 1) digitalWrite(13, HIGH);
You can remove the two includes (EthernetUdp.h and SPI.h), they are included for the other example with UDP.
If you are not using the ethernet version, there is no port to specify.
