Hello Everybody,
I have made available the Arduino support for the NetworkViewer interface I am working on for the OpenECoSys (Open Embedded Computing Systems) project:
This is work in progress, but you can already use it for visualization of internal variables in real-time. This can be useful for viewing ADC values in real-time like a simple oscilloscope for instance. I have made a little tutorial on how to use the system at :
I have tested it on Arduino UNO and it works perfectly for me. It should also work pretty well on ChipKit derivatives.
The idea behind NetworkViewer is that we need to be able to monitor internal states of micro-controllers while they are running to avoid breaking their real-time constraints. My goal is to provide an easy-to-use interface that is cross-platform and versatile. Supporting multiple communication hardware from the same interface is also required. Right now, NetworkViewer supports Ethernet, CAN and serial. They are available as dynamic (loaded at run time) drivers. Over time, other plugins will be created to support other communication devices. My short term goal is to support multiple communication protocols at once to display an unified view of the heterogenous network through the NetworkViewer interface. Scripting and logging is also available as software plugins. More information about NetworkViewer can be found here :
All comments and suggestions are welcomed.
Regards,
Dominic Létourneau
http://www.openecosys.org
