Opening a SD file with a variable
Quick question.
I have a routine that opens Help files that are stored on an SD card.
I currently access them with a lengthy switch case statement (There are 50+ .txt files).
How can I open an SD file using the variable of the help file I am currently accessing?
HelpPage is the variable 1-50 depending on the page I am opening.
The stored filenames are "Help1.txt", "Help2.txt", "Help3.txt", "Help4.txt" etc
E.G.
myFile = SD.open("HELP"+HelpPage+".txt");
Obviously this arrangement doesn't work, but wondered if it's possible?
Declare a static var fileName
char fileName[11]; // Helpxx.txt + '\0' = 11 char
set fileName with setFilename(n)
void setFilename(int n)
	if ((n<0) || (n>50))
                // error, n out of range
                fileName[0] = '\0';
		return;
	sprintf(fileName,"Help%d.txt",n);
for example, to open “Help23.txt”
setFilename(23);
myFile = SD.open(fileName);
Thank you VLC. I was on the right lines, but I don't think I would have got there.
I will try that tomorrow.
if HelpPage is a byte or int then you need a cast
myFile = SD.open("HELP"+String(HelpPage)+".txt");
Many thanks
Worked a treat
String(HelpPage) is NOT a cast.
Hi paul. here is a link to the official arduino page for converting ints to strings. i am aware that some of the serial print functions convert for you but wasnt aware of any casts in the SD library. if you have a better or more proficient way of casting I am always learning.
Converting an int to a String is NOT the same as casting an int to a String. A cast says that the compiler should treat the bit pattern that is an int as though it was a String. An that is NOT a meaningful thing to do.
Creating a String that wraps a string that represents the int is something completely different.
