Whenever I save a project and try to open it, it just creates a new project. How do I open the file?
What did you use for a file name?
Was this file name in a folder with the same filename?
What code did you enter before saving it?
Have you searched your "My Documents" folder of any file with the ino file extension?
The file name and folder name are the same. The file did definitely save because I can open it in notepad and the code is there.
"Have you searched your "My Documents" folder of any file with the ino file extension?" What do you mean?
Which operating system?
Which version of the IDE?
Can you elaborate? As I read it you start a new sketch and save it with a given name. If you save it again it prompts you for a new name?
Menu File → Open or File → Open Recent? And if there is a file association with the IDE double clicking the ino file should do.
Windows 10, 2.3.6
When I try to open the file it creates a new file that is blank and is named the current date.
How do I open the file instead of creating a new blank one?
How? Double click in Windows Explorer or from the File menu?
Where are your files stored? Local disk or elsewhere?
I am sure I saw this issue not long ago. Have you checked github or searched this forum for the same issue?
I have tried opening from arduino ide. I have tried double clicking from file explorer. I've tried dragging from file explorer to arduino ide. The only way the code appears is dragging into notepad.
