Opening relays with SIM900A
Hallo there!
I'm a rookie with Arduino and coding.
I bought som parts from ebay in order to control som relays with a text message.
I used this guide and the code from it, but nothing happens when I send a text to my module.
My SIM module is registret on the network and the signal indicator flashes when it receives the text. Im in Denmark - Europe if that matters. I read something about the SIM900A wouldn't work in Europe? But its on the network and does obviously receives signal. I can also call the device with af normal phone call.
Can anybody tell me what's wrong?
I know my setup isn't the same with LEDs. But I cant see why that should matter?
Hope you can help med :slight_smile:
The code:
char inchar; //Will hold the incoming character from the Serial Port.
int led1 = 8;
int led2 = 9;
int relay1=7;
int relay2=6;
// prepare the digital output pins
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
digitalWrite(7,HIGH);
digitalWrite(6,HIGH);
Serial.print("pin state low\n");
delay(3000); // give time for GSM module to register on network.
Serial.println("AT+CMGF=1"); // set SMS mode to text
delay(200);
Serial.println("AT+CNMI=2,2,0,0,0"); // set module to send SMS data to serial out upon receipt
delay(200);
//If #a1b1c1d1 comes as sms, all led's should light up.
if(Serial.available() >0)
inchar=Serial.read();
if (inchar=='#')
delay(10);
//first led
if (inchar=='a')//closed
delay(10);
if (inchar=='0')//closed
digitalWrite(relay1,HIGH);
Serial.print("Relay 1 LOW\n");
// delay(1000);
// Serial.println("AT+CMGD=1,4"); //Delete all message
Serial.println("AT+CMGS="9894273273"");//Change the receiver phone number
Serial.print("Power OFF"); //the message you want to send
Serial.write(26);
else if (inchar=='1')
digitalWrite(led1, HIGH);
digitalWrite(relay1, LOW);
Serial.print("Relay 1 HIGH\n");
// delay(1000);
Serial.print("Power ON"); //the message you want to send
Serial.write(26);
delay(10);
if(inchar=='b')
delay(10);
if (inchar=='0')
digitalWrite(relay2,HIGH);
Serial.print("Relay 2 LOW\n");
//Serial.println("AT+CMGD=1,4"); //Delete all message
/* delay(500);
Serial.print("Light OFF"); //the message you want to send
Serial.write(26);
delay(500);*/
// Serial.print("Light OFF");
digitalWrite(led2, HIGH);
digitalWrite(relay2, LOW);
Serial.print("Relay 2 HIGH\n");
/delay(500);
Serial.print("Light ON");//the message you want to send
Serial.write(26);
// Serial.print("Light ON");
pic
