Now I need a solution to turn the are through 90degrees. The above item uses a worm drive is suspect.
But I was wondering if anyone has a good idea for a motor? Suggestions welcome:-)
Cheers
Steve
greenblood:
I don't know what you had in mind when you wrote that.
A worm-gear drive is a convenient way to get a large gear reduction and also to have a mechanism where the force on the shutter cannot move the motor. Why would it be suspect?
Another interpretation of your words is that the item uses the motor to drive a lead-screw to convert rotary motion into linear motion. That is also a very common system - why would it be suspect?
...R
PS ... by the time you have designed, tested and created a system that is sufficiently robust and reliable I think you will conclude that 200 Euros is not an outrageous price.
Is suspect = I suspect, blame spell check!
Yes, I have looked at motors and servos and the costs quickly add up. 200e doesn’t seem bad at all.
However, the minimum 85cm space required will be. I may contact the manufacturer and see if there is any way it can be made to fit an opening nearer 50cm...
