OpenLOG and Arduino Micro
Hi everybody!
I have a problem with the combination of OpenLog (Sparkfun) and Arduino Micro!
The communication with Arduino Micro to OpenLog is on Serial1 (Pin 0 and 1)
The status led (blue) on OpenLog is indicating that serial data is received (test code see below)
the problem:
sd card is empty!
Settings:
micro sd card, formatted to Fat32 with windows8, 3.64 GB
TX (Ard) -> RXI (OpenLog)
Pin5(Ard) -> VCC (OpenLog)
GND(Ard) -> GND
A similar code was working with Arduino Uno.
Any ideas whats the problem?
int ledPin =  13; //Status LED connected to digital pin 13
  pinMode(ledPin, OUTPUT);
  pinMode(5,OUTPUT);  //power for open log
  digitalWrite(5,HIGH); //power for open log
  delay(1000); //Wait a second for OpenLog to init
  Serial1.begin(9600); //9600bps is default for OpenLog
  Serial1.println();
  Serial1.println("Run OpenLog Test");
  int testAmt = 4;
  //Each test is 100 lines. 10 tests is 1000 lines (11,000 characters)
  for(int numofTests = 0 ; numofTests < testAmt ; numofTests++)
    //This loop will print 100 lines of 110 characters each
    for(int k = 33; k < 43 ; k++)
      //Print one line of 110 characters with marker in the front (markers go from '!' to '*')
      Serial1.write(k); //Print the ASCII value directly: ! then " then #, etc
      Serial1.println(":abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ-!#");
      //Then print 9 lines of 110 characters with new line at the end of the line
      for(int i = 1 ; i < 10 ; i++)
        Serial1.print(i, DEC);
      if(digitalRead(ledPin) == 0) //Turn the status LED on/off as we go
        digitalWrite(ledPin, HIGH);
        digitalWrite(ledPin, LOW);
  } //End numofTests loop
  unsigned long totalCharacters = (long)testAmt * 100 * 110;
  Serial1.print("Characters pushed: ");
  Serial1.println(totalCharacters);
  Serial1.print("Time taken (s): ");
  Serial1.println(millis()/1000);
  Serial1.println("Done!");
while(true)
    //Blink the Status LED because we're done!
    delay(100);
    delay(100);
    delay(100);
    delay(5000);
Ok, i found the problem by myself:
It works, if i wire the VCC of OpenLog to 5V-pin of the Arduino Micro.
so it was definitely a power problem (too less?)
but iam not sure why it is not working on Pin5 (output - high)?
(i measured 3.3 V at Pin5 with multimeter if openLOG was connected)
:slight_smile:
