So i’ve managed to get the camera to work by modifying and using this code(I modified baud rate to 38400 instead of the original, 9600. I’m also not using VC0706 cam. I’m using LSY-201 camera:
#include <camera_VC0706.h>
#include <SD.h>
#include <SoftwareSerial.h>
#if ARDUINO >= 100
SoftwareSerial cameraconnection = SoftwareSerial(5, 6);
#else
NewSoftSerial cameraconnection = NewSoftSerial(5, 6);
#endif
camera_VC0706 cam = camera_VC0706(&cameraconnection);
Serial.begin(38400);
Serial.println("VC0706 Camera snapshot test");
// Try to locate the camera
if (cam.begin()) {
Serial.println("Camera Found:");
Serial.println("No camera found?");
return;
// Print out the camera version information (optional)
char *reply = cam.getVersion();
if (reply == 0) {
Serial.print("Failed to get version");
Serial.println("-----------------");
Serial.print(reply);
cam.setImageSize(VC0706_640x480); // biggest
//cam.setImageSize(VC0706_320x240); // medium
//cam.setImageSize(VC0706_160x120); // small
// You can read the size back from the camera (optional, but maybe useful?)
uint8_t imgsize = cam.getImageSize();
Serial.print("Image size: ");
if (imgsize == VC0706_640x480) Serial.println("640x480");
if (imgsize == VC0706_320x240) Serial.println("320x240");
if (imgsize == VC0706_160x120) Serial.println("160x120");
Serial.println("Snap in 3 secs...");
delay(3000);
if (! cam.takePicture())
Serial.println("Failed to snap!");
Serial.println("Picture taken!");
// Create an image with the name IMAGExx.JPG
char filename[13];
strcpy(filename, "IMAGE00.JPG");
for (int i = 0; i < 100; i++) {
filename[5] = '0' + i/10;
filename[6] = '0' + i%10;
// create if does not exist, do not open existing, write, sync after write
if (! SD.exists(filename)) {
// Open the file for writing
File imgFile = SD.open(filename, FILE_WRITE);
// Get the size of the image (frame) taken
uint16_t jpglen = cam.frameLength();
Serial.print("Storing ");
Serial.print(jpglen, DEC);
Serial.print(" byte image.");
int32_t time = millis();
pinMode(8, OUTPUT);
// Read all the data up to # bytes!
byte wCount = 0; // For counting # of writes
while (jpglen > 0) {
// read 32 bytes at a time;
uint8_t *buffer;
uint8_t bytesToRead = min(32, jpglen); // change 32 to 64 for a speedup but may not work with all setups!
buffer = cam.readPicture(bytesToRead);
imgFile.write(buffer, bytesToRead);
if(++wCount >= 64) { // Every 2K, give a little feedback so it doesn't appear locked up
Serial.print('.');
wCount = 0;
//Serial.print("Read "); Serial.print(bytesToRead, DEC); Serial.println(" bytes");
jpglen -= bytesToRead;
imgFile.close();
time = millis() - time;
Serial.println("done!");
Serial.print(time); Serial.println(" ms elapsed");
My console reads as following:
Camera Found:
VC0703 1.00
No ctrl infr
MI360
625
Init end
Image size: 640x480
Snap in 3 secs...
Picture taken!
Storing 45808 byte image.......................done!
15229 ms elapsed
The SD card saves using SERIAL so it means that everything in the console gets saved to the SD card i believe. My question is, how can i loop this code to take screenshots every 5 seconds? And also, is there anything i can remove and shorten in the code to make it a lot more simple?
Something else i noticed is that it takes about 5 to 10 seconds for the image to save into the SD card… is there anything i can do to fasten the proccess and save the image very quickly? “…done!” takes about 5-10 secs.
Thanks!
Hello, i’m really new to arduino but i’m trying to capture photos with a camera connected to the arduino. First of all i have to get the SD card to work, which i’m not sure it is. It’s the openlog module and it’s connected with RX directly to TX in the uno board, and TX directly to the RX. If i understood correctly it’s supposed to log everything with “printIn” command. But i’m trying to test if the SD Card works by using the SD Card Test, however it seems to fail connection with te SD Card.
Is this perhaps because i need to edit the default “const int chipSelect = 4;” to something else than 4? I’m not sure what ChipSelect means, or where i can figure out where this chip is connected to, on the board?
Thanks.
