OpenMV COmmunication
I'm using an Arduino Mega and an OpenMV H7 Plus and attempting to communicate between them using UART.
Here's the program for the OpenMV
import sensor, image, time
from pyb import UART
uart = UART(3,19200)
thresholds = [(64, 66, -51, 47, -31, 34), #Threshold for blue. These are the Min and Max values of L, A, and B colour space.
(38, 40, -5, 2, 40, 46)] #Threshold for yellow
sensor.reset()
sensor.set_pixformat(sensor.RGB565)
sensor.set_framesize(sensor.QVGA)
sensor.skip_frames(time = 2000)
sensor.set_auto_gain(False) # must be turned off for color tracking
sensor.set_auto_whitebal(False) # must be turned off for color tracking
clock = time.clock()
sensor.set_brightness(2)
while(True):
img = sensor.snapshot()
for blob in img.find_blobs([thresholds[0]], pixels_threshold=200, area_threshold=200, merge=True):
    img.draw_rectangle(blob.rect()) #draw a rectangle around the blue object
    img.draw_cross(blob.cx(), blob.cy()) # add a cross in the centre of the object
    uart.write("Blue x: ""%d"%blob.cx())
    uart.write(" y: ""%d\n"%blob.cy())
    print("Blue x: " "%d"%blob.cx(), "y: ""%d\n"%blob.cy()) #print the x and y values of the object
for blob in img.find_blobs([thresholds[1]], pixels_threshold=200, area_threshold=200, merge=True):
    uart.write("Yellow x: ""%d"%blob.cx())
    print("Yellow x: " "%d"%blob.cx(), "y: ""%d\n"%blob.cy())  #print the x and y values of the object
And here's the Arduino code
void setup(){
Serial3.begin(19200);
Serial.begin(19200);
void loop(){
if(Serial3.available()){
byte CamOut = Serial3.read();
Serial.print(CamOut);
For some reason, the TX0 and RX0 work as input and outputs from the camera, but the 3s don't.
Any ideas why? When I use the 0s the serial monitor on both ends works. Why does this happen?
Also, I was trying to use the OpenMV without it connected to my PC and power it with the Arduino. I've tried disconnecting the camera from my computer, connecting the vin to the 5v on the mega, but all it does is blink blue and doesn't do anything. I used the same programs as above. What should I do?
Probably swapped connection. TX0/RX0 are directly connected to the USB2serial converter, so there it may work without the sketch even loaded.
Post a wiring diagram!
Here's a photo
Correct me if I'm wrong but on the picture the wires are from P3/P4 instead of P0/P1 as the pinout suggests.
BTW, that OpenMV board is on 3.3V, the Mega runs on 5V. You must not connect them directly!
