I'm using Ubuntu 16.04 and IDE Arduino 1,8,5.
I Bought an Arduino Due Board; Added myself to dialout and tty group, then connected an Adruino Due board, with the Programming port.
BUT trying to load the blink example, I got the ERROR below.
Consider that, as shown below, the board can be found by sudo lsusb command, by the IDE still can not connect to the board (As normal user).
Any Ideas how to connect to the Arduino Due Board ??
Caused by: jssc.SerialPortException: Port name - /dev/ttyACM0; Method name - openPort(); Exception type - Permission denied.
at jssc.SerialPort.openPort(SerialPort.java:170)
at processing.app.Serial.touchForCDCReset(Serial.java:101)
giuliano@hotbird13:~$ groups giuliano
giuliano : giuliano adm tty dialout cdrom sudo dip plugdev lpadmin sambashare kismet
giuliano@hotbird13:~$ ls -l /dev/ttyACM*
crw-rw---- 1 root dialout 166, 0 set 28 21:04 /dev/ttyACM0
giuliano@hotbird13:~$ sudo lsusb -d 0x2341:0x003d -v
Bus 003 Device 008: ID 2341:003d Arduino SA
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 2 Communications
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x2341 Arduino SA
idProduct 0x003d
bcdDevice 0.01
iManufacturer 1 Arduino (www.arduino.cc)
iProduct 2 Arduino Due Prog. Port
iSerial 220 557393236373516192C0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 62
bNumInterfaces 2
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 2 Communications
bInterfaceSubClass 2 Abstract (modem)
bInterfaceProtocol 1 AT-commands (v.25ter)
iInterface 0
CDC Header:
bcdCDC 10.01
CDC ACM:
bmCapabilities 0x06
sends break
line coding and serial state
CDC Union:
bMasterInterface 0
bSlaveInterface 1
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 255
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 10 CDC Data
bInterfaceSubClass 0 Unused
bInterfaceProtocol 0
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
Device Status: 0x0000
(Bus Powered)
