Hello!
We want to get data from the boiler and store it. I found some examples and a PDF file with all Opentherm ID's.
I just cant find a good explanation to make the binery code.
I for example want to include the return water temp. This has ID 28. How do i make the opentherm binary command?
P MGS-TYPE SPARE DATA-ID DATA-VALUE
0 000 0000 00000000 00000000 00000000
I hope someone can help me and explain to me how i make the binary command:)
kind regards!
horace
2
have you had a look at the opentherm library
Thank you for the reply!
No i was using a different library. this helps a lot already.
But how do i need to write the code when i want to get the return water temp for example?
For example i found you can just type:
float retour = ot.getReturnTemprature();
Serial.println("Retour temperature is " + String(retour) + " degrees C");
In my code it doesnt turn orange.
Am i doing something wrong?
system
Closed
6
