Hello,
I encounter a problem with my code where after the first successful data fetch, I get null values consistently. I am not sure how to remedy this, as only on the first data fetch it always returns and prints a value on the LCD.
Here's the code (removed some stuff except for key for privacy reasons)
#include <TFT_eSPI.h>
#include <Wire.h>
#include <WiFi.h>
#include <esp_eap_client.h>
#include <time.h>
#include <HTTPClient.h>
#include <Arduino_JSON.h>
TFT_eSPI tft = TFT_eSPI(); // Invoke library
#define EAP_IDENTITY "identity"
#define EAP_USERNAME "user"
#define EAP_PASSWORD "pass"
const char* ssid = "ssid";
int counter = 0;
String openWeatherMapApiKey = "0c4ba1c6318bce1a1d505959054f2239";
String city = "city";
String countryCode = "code";
unsigned long lastTime = 0;
unsigned long timerDelay = 10000;
String jsonBuffer;
tft.begin();
tft.fillScreen(TFT_BLACK);
tft.setCursor(0,40);
tft.setTextSize(2);
tft.print("Loading...");
Serial.print("Connecting to network: ");
Serial.println(ssid);
WiFi.disconnect(true);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, WPA2_AUTH_PEAP, EAP_IDENTITY, EAP_USERNAME, EAP_PASSWORD);
Serial.print(".");
counter++;
if(counter>=60){ //after 30 seconds timeout - reset board
ESP.restart();
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address set: ");
Serial.println(WiFi.localIP()); //print LAN IP
if ((millis() - lastTime) > timerDelay) {
// Check WiFi connection status
if(WiFi.status()== WL_CONNECTED){
String serverPath = "http://api.openweathermap.org/data/2.5/weather?q=" + city + "," + countryCode + "&units=metric" + "&APPID=" + openWeatherMapApiKey;
jsonBuffer = httpGETRequest(serverPath.c_str());
Serial.println(jsonBuffer);
JSONVar myObject = JSON.parse(jsonBuffer);
// JSON.typeof(jsonVar) can be used to get the type of the var
if (JSON.typeof(myObject) == "undefined") {
Serial.println("Parsing input failed!");
return;
Serial.print("JSON object = ");
Serial.println(myObject);
Serial.print("Temperature: ");
Serial.println(myObject["main"]["temp"]);
Serial.print("Pressure: ");
Serial.println(myObject["main"]["pressure"]);
Serial.print("Humidity: ");
Serial.println(myObject["main"]["humidity"]);
Serial.print("Wind Speed: ");
Serial.println(myObject["wind"]["speed"]);
// print temp
tft.setTextColor(TFT_WHITE);
tft.setCursor(tft.width()/6, 40);
tft.setTextSize(4);
tft.print(myObject["main"]["temp"]);
tft.print((char)247);
tft.print("C");
// print min/max temp
tft.setTextSize(2);
tft.setCursor(0,70);
tft.setTextColor(TFT_RED);
tft.print("Min:");
tft.print(myObject["main"]["temp_min"]);
tft.println("C");
tft.setTextColor(TFT_GREEN);
tft.print("Max:");
tft.print(myObject["main"]["temp_max"]);
tft.print("C");
// print conditions
tft.setCursor(0, 115);
tft.setTextSize(2);
tft.setTextColor(TFT_LIGHTGREY);
tft.print("Conditions:");
tft.setCursor(0, 135);
tft.setTextSize(3);
tft.print(myObject["weather"][0]["main"]);
tft.setCursor(0, 160);
tft.setTextSize(2);
tft.setTextColor(TFT_ORANGE);
tft.print("Description:");
tft.setCursor(0, 180);
tft.print(myObject["weather"][0]["description"]);
delay(100000);
else {
Serial.println("WiFi Disconnected");
lastTime = millis();
if (WiFi.status() == WL_CONNECTED) { //if we are connected to Eduroam network
counter = 0; //reset counter
Serial.println("Wifi is still connected with IP: ");
}else if (WiFi.status() != WL_CONNECTED) { //if we lost connection, retry
WiFi.begin(ssid);
while (WiFi.status() != WL_CONNECTED) { //during lost connection, print dots
Serial.print(".");
counter++;
if(counter>=60){ //30 seconds timeout - reset board
ESP.restart();
bool i2CAddrTest(uint8_t addr) {
Wire.begin();
Wire.beginTransmission(addr);
if (Wire.endTransmission() == 0) {
return true;
return false;
String httpGETRequest(const char* serverName) {
WiFiClient client;
HTTPClient http;
// Your Domain name with URL path or IP address with path
http.begin(client, serverName);
// Send HTTP POST request
int httpResponseCode = http.GET();
String payload = "{}";
if (httpResponseCode>0) {
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode);
payload = http.getString();
else {
Serial.print("Error code: ");
// Free resources
http.end();
return payload;
