OpenWRT 1.6.2 and PHP
Hi, i've a question about OpenWRT 1.6.2 and PHP. On OpenWRT 1.5.3 i can install PHP and use it on Arduino YUN but with 1.6.2 version i can't. If i browse to PHP page i can download it but i can't see in browser. Is there a solution for this?
Thanks, Gabriele MagicBotolo
Same problem with me also. please help. :confused:
@magicbotolo, how did you install and download your PHP engine? Jesse
I have fixed this problem just now :)
The solution is to replace the contents of the file /etc/config/uhttpd with the following ( I got it from the previous 1.5.3 firmware ) :
# Server configuration
config uhttpd main
 # HTTP listen addresses, multiple allowed
 list listen_http 0.0.0.0:80
# list listen_http [::]:80
 # HTTPS listen addresses, multiple allowed
 list listen_https 0.0.0.0:443
# list listen_https [::]:443
 # Server document root
 option home /www
 # Reject requests from RFC1918 IP addresses
 # directed to the servers public IP(s).
 # This is a DNS rebinding countermeasure.
 option rfc1918_filter 0
 # Maximum number of concurrent requests.
 # If this number is exceeded, further requests are
 # queued until the number of running requests drops
 # below the limit again.
 option max_requests 2
 # Certificate and private key for HTTPS.
 # If no listen_https addresses are given,
 # the key options are ignored.
 option cert /etc/uhttpd.crt
 option key /etc/uhttpd.key
 # CGI url prefix, will be searched in docroot.
 # Default is /cgi-bin
 option cgi_prefix /cgi-bin
 # List of extension->interpreter mappings.
 # Files with an associated interpreter can
 # be called outside of the CGI prefix and do
 # not need to be executable.
 list interpreter ".php=/usr/bin/php-cgi"
# list interpreter ".cgi=/usr/bin/perl"
 # Lua url prefix and handler script.
 # Lua support is disabled if no prefix given.
# option lua_prefix /luci
# option lua_handler /usr/lib/lua/luci/sgi/uhttpd.lua
 # CGI/Lua timeout, if the called script does not
 # write data within the given amount of seconds,
 # the server will terminate the request with
 # 504 Gateway Timeout response.
 option script_timeout 60
 # Network timeout, if the current connection is
 # blocked for the specified amount of seconds,
 # the server will terminate the associated
 # request process.
 option network_timeout 30
 # TCP Keep-Alive, send periodic keep-alive probes
 # over established connections to detect dead peers.
 # The value is given in seconds to specify the
 # interval between subsequent probes.
 # Setting this to 0 will disable TCP keep-alive.
 option tcp_keepalive 1
 # Basic auth realm, defaults to local hostname
# option realm OpenWrt
 # Configuration file in busybox httpd format
# option config /etc/httpd.conf
# Certificate defaults for px5g key generator
config cert px5g
 # Validity time
 option days 36500
 # RSA key size
 option bits 1024
 # Location
 option country IT
 option state Turin
 option location Turin
 # Common name
 option commonname 'Arduino LLC'
Finally its alive |500x269
@Omar, thanks for posting the solution. I'm sure it will help others in the future. Jesse
jessemonroy650:
@Omar,
thanks for posting the solution. I’m sure it will help others in the future.
Jesse
You are welcome. Yes it will.
