openwrt-yun compile in ubuntu 12.04 fail
Hi all,
I tried to build openwrt-yun on ubuntu 12.04 and unfortunately it failed.
Because package opkg could find libcurl. Here is the log:
checking for CURL... configure: error: Package requirements (libcurl) were not met:
No package 'libcurl' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables CURL_CFLAGS
and CURL_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
make[2]: *** [/media/opt/Arduino/openwrt-yun/build_dir/linux-ar71xx_generic/opkg-618/.configured_yyyy] Error 1
make[2]: Leaving directory `/media/opt/Arduino/openwrt-yun/package/opkg'
Did anyone meet this issue before?
BTW: I know it is recommanded to use Debian, but why not Ubuntu. Ubuntu is more popular OS for developing.
Thansk
Is the CURL library installed?
Thanks for reply!
Yes, I tried a lot of libcurl installation ways:
sudo apt-get install libcurl4-openssl-dev
sudo apt-get install libcurl4-gnutls-dev
and 'pkg-config --libs libcurl' output:
-L/usr/local/lib -lcurl
Any suggestion?
Okay. Not sure which machine you are working on, but I don't see the path
/usr/local/lib
I do see
/usr/lib
and in that path I see
/usr/lib/libcurl.so.4.3.0
Maybe try to link to that. or make the link to your program so it uses a "shared object"
Let me know if that works.
Jesse
