so if I wanted to create my own GUI I just have to edit that CSS file ? what if I wanted to modify the code behind those buttons? is there a program I can use to change the gui like dreamweaver? (im lazy).
so in the include section of the code I changed the <> to "" and it compiled. I also managed to have a look at the code in the .htm files using dreamweaver.
if i wanted to make my own version of this would I just build a website using a package like dreamweaver ?
i have to say very nice UI but very slow i tried to modify little bit like to use background-color grey instead of png i did a png reduce but still very slow.
can someone make faster...? any ideas?? can we add all the spare digital pins too ? and how? i cant even change the led names if i do this i lost the on of png...
and something last nice round png but its more easy to draw a cicle or a square like RED on OFF and Green or Blue on ON ?????? thanks for your effort keep up.... bravo
nikkpap:
yeah I noticed it was slow too but I think it is browser dependant. I tried it on Dolphin browser for android and it was slow but using the stock android browser it was a little bit faster.
Quote from: nikkpap on July 11, 2012, 02:42:49 AM
nice UI. I've developed an Ajax web interface where the page wasn't loaded from the webserver but straight from the mobile device.
In practise, the page is stored on the mobile device, when loaded it start to send JSONP requestes to the server, that is no longer a webserver but a Json server.
In that way the functionality is preatty the same, but the poor Arduino board isn't overloaded in RAM and can react much faster.
The post where I've placed the code is there, unfortunately is only in Italian. The webpage is the same of the TinyWebServer.
I've used this library in the Souliss project to build easily an universal interface. The interface was working but not nice enough on the UI side, if you are interested in, you can use your UI for that project.
I must confess that I am not a good coder, but I am good at adaptation.
I was thinking to offload webpage from Arduino to any damn web-server as Arduino is not suitable for this kind of workload.
the Arduino sketch remains same for IDE 1.01 other than you have to substitute "Server" to "Ethernetserver" and "Client" to "EthernetClient".
Attached below Arduino sketch and Htmlpart.zip.
Upload AjaxUI.ino to arduino
Extract htmlpart.zip to your Pc/Mac/Phone/Tablet
Open Index.htm in your browser give password 4587 and hit submit. (don't press enter/return)
Out of the example in the post that I've linked, there is a full UI for the Souliss Home Automation that I've developed for the past releases. This UI is no longer maintained for time reason, bacause the project is focusing the time on others UIs (Android and Java).
If you are interested in reworking the UI, you can use the Souliss A2.1 release and figure out how was worked. Is working but not nice enough
Behind the UI there is a full home automation framework that runs over the ATmega.
Turkeybaster:
what did you use to build the android application ?
We used standard Android SDK on Eclipse. App supports VPN communications, private and/or public address, so that network latency is tuned to connection speed. Much work is still to be done, but the app is working properly so far.
Hi guys:
I see you have also problems with latency
I was testing very ways to do a Arduino Web Sever
with the library Tinywebserver ist actually very good.....but i would like to build other kind of controls like real time sliders and not only on/of buttons.
My issue is:
Is it posible to send UDP messages between arduino and the web based user interface with the Tinywebserver library??
I comunicate the arduino board with Internet in two ways:
The software tool VVVV: is there a node which made all the hard job for you and works great....but
VVVV works just for rapid prototyping but im not sure that a "vvvv based user interface" could be a" end user" solution.
The other way is a PHP based web server. it works very nice and fast when you use UPD messages..but the problem the server is my PC not the Arduino Board....
