Operating motor using GSM SIM900a module
Hi All,
My project is to operate a motor using SMS send from my mobile to GSM module (with Arduino Uno). I am using the following code. However, the code works sometimes and not other times. Not sure what is happening exactly. Could anyone please shed some light on this? Here comes the code I am using
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11);
int LED = 8;
int motor = 9;
int temp=0;
int i=0;
char str[15];
mySerial.begin(9600); // Setting the baud rate of GSM Module
Serial.begin(9600); // Setting the baud rate of Serial Monitor (Arduino)
pinMode(motor,OUTPUT);
pinMode(LED,OUTPUT);
digitalWrite(motor,LOW);
digitalWrite(LED,LOW);
delay(50);
SendMessage();
serialEvent();
RecieveMessage();
if (mySerial.available()>0)
Serial.write(mySerial.read());
//Serial.write(str, i);
void SendMessage()
mySerial.println("AT+CMGF=1"); //Sets the GSM Module in Text Mode
delay(1000); // Delay of 1000 milli seconds or 1 second
mySerial.println("AT+CMGS="xxxxxxxxx"\r"); // Replace x with mobile number
mySerial.println("System is up and ready");// The SMS text you want to send
mySerial.println((char)26);// ASCII code of CTRL+Z
void serialEvent()
ClearStrArray();
while (mySerial.available())
if(mySerial.find("/"))
while(mySerial.available())
char inChar=mySerial.read();
str[i++] = inChar;
if (inChar=='/') break;
i = i-1;
void ClearStrArray() // function to clear buffer array
// for (int j = 0; j < i; j++)
memset(0, str, sizeof(str));
// str[i]= '\0';
// } // clear all index of an array with command NULL
i = 0;
void RecieveMessage()
mySerial.println("AT+CNMI=2,2,0,0,0"); // AT Command to recieve a live SMS
//delay(100);
if(!(strncmp(str,"motor on",8)))
digitalWrite(motor,HIGH);
digitalWrite(LED,HIGH);
delay(50);
delay(50); // Delay of 1000 milli seconds or 1 second
mySerial.println("AT+CMGS="xxxxxxxxxx"\r"); // Replace x with mobile number
delay(50);
mySerial.println("Motor Activated");// The SMS text you want to send
delay(50);
delay(50);
else if(!(strncmp(str,"motor off",9)))
delay(50);
delay(50);
mySerial.println("Motor Deactivated");// The SMS text you want to send
delay(50);
delay(50);
else if(!(strncmp(str,"test",4)))
delay(50);
delay(50);
mySerial.println("The System is Working fine");// The SMS text you want to send
delay(50);
delay(50);
Thanks much in anticipation​ ​ ​ ​
Edit your post and put the code in code tags so it is much easier to read.
