opkg update command fails 'Signature check fails Remove wrong signature file'
Hello-
When I run 'opkg update' it fails. The only place I see this message listed in the forum is here
http://forum.arduino.cc/index.php?topic=211126.0
In that case it was a DHCP issue. I checked all of my configs on the network and they seem to be good.
Here is the output from the terminal session on my Yún
root@dribbleb:~# ifconfig
eth1 Link encap:Ethernet HWaddr 90:A2:DA:F8:0C:88
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:4
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:64 errors:0 dropped:0 overruns:0 frame:0
TX packets:64 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:6691 (6.5 KiB) TX bytes:6691 (6.5 KiB)
wlan0 Link encap:Ethernet HWaddr 90:A2:DA:F0:0C:88
inet addr:192.168.1.13 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:3386 errors:0 dropped:373 overruns:0 frame:0
TX packets:830 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1360167 (1.2 MiB) TX bytes:93349 (91.1 KiB)
root@dribbleb:~# ping download.linino.org
PING download.linino.org (88.198.63.58): 56 data bytes
64 bytes from 88.198.63.58: seq=0 ttl=250 time=194.131 ms
64 bytes from 88.198.63.58: seq=1 ttl=250 time=188.743 ms
64 bytes from 88.198.63.58: seq=2 ttl=250 time=194.145 ms
64 bytes from 88.198.63.58: seq=3 ttl=250 time=200.616 ms
64 bytes from 88.198.63.58: seq=4 ttl=250 time=195.573 ms
64 bytes from 88.198.63.58: seq=5 ttl=250 time=196.449 ms
64 bytes from 88.198.63.58: seq=6 ttl=250 time=198.029 ms
64 bytes from 88.198.63.58: seq=7 ttl=250 time=204.724 ms
64 bytes from 88.198.63.58: seq=8 ttl=250 time=197.963 ms
64 bytes from 88.198.63.58: seq=9 ttl=250 time=197.892 ms
64 bytes from 88.198.63.58: seq=10 ttl=250 time=195.869 ms
64 bytes from 88.198.63.58: seq=11 ttl=250 time=196.871 ms
64 bytes from 88.198.63.58: seq=12 ttl=250 time=197.131 ms
^C
--- download.linino.org ping statistics ---
13 packets transmitted, 13 packets received, 0% packet loss
round-trip min/avg/max = 188.743/196.779/204.724 ms
root@dribbleb:~# opkg update
Downloading http://downloads.arduino.cc/openwrtyun/1/packages/Packages.gz.
Updated list of available packages in /var/opkg-lists/attitude_adjustment.
Downloading http://downloads.arduino.cc/openwrtyun/1/packages/Packages.sig.
Signature check failed.
Remove wrong Signature file.
Would anyone have any suggestions? I am completely miffed.
