opkg update problem
I am trying to install "kmod-usb-serial-ftdi" so I have to make "opkg update" and this is what I get
Downloading http://downloads.arduino.cc/openwrtyun/1/packages/Packages.gz.
Updated list of available packages in /var/opkg-lists/attitude_adjustment.
Downloading http://downloads.arduino.cc/openwrtyun/1/packages/Packages.sig.
Signature check failed.
Remove wrong Signature file.
any help?
Just done and works fine. Maybe some issue with the downloads server. Can you retry?
same as before
I'm puzzled. Can you paste the output of command
cat /etc/arduino/openwrt-yun-release
root@Arduino:~# cat /etc/arduino/openwrt-yun-release
built=Sat May 17 11:59:28 CEST 2014
I'm still puzzled. My yun was not as up to date as yours. I've updated it. opkg is still successful
root@Arduino:~# opkg update
Signature check passed.
yes what do you think. is there any way to retrieve the older version of Linux
I have finally solved my problem I installed an older version of linino you can find it here http://download.linino.org/linino_distro/master/latest/openwrt-ar71xx-generic-linino-yun-16M-250k-squashfs-sysupgrade.bin and it is working well.
