Opla IoT Kit - LEDs have wrong colours
Hello!
Got the Opla IoT Kit and started to light up the leds. But they have wrong colors:
LED0 is green, LED1 is red and LED2 is blue. Used this code:
carrier.leds.setPixelColor(0, 125, 0, 0);
carrier.leds.setPixelColor(1, 0, 125, 0);
carrier.leds.setPixelColor(2, 0, 0, 125);
Seems like LED0 and LED1 are wrong.
Another strange thing is the board freezes from time to time when a new sketch has been loaded. I have to disconnect it from USB / battery (18650 installed) and connect again then. This also happens with the example sketches – so I think there´s no problem with the code. Tried it on the Mac & PC – both are the same.
Any ideas what may cause this?
Best regards,
Jean
Please post your complete sketch and a schematic of your project
The schematic of the Arduino MKR IoT Carrier of the Oplà IoT Kit is on the “Documentation” tab of this page:
https://store.arduino.cc/mkr-iot-carrier
I can see that the library it uses the Adafruit DotStar library to control the LEDs, meaning they are the addressable APA102 or compatible.
I can see here that a fix has been submitted for the swapped LED colors:
@jeandlx. If you want to try out that fix and want instructions, I’m happy to provide them.
Hello @pert !
Here is the code:
#include <Arduino_MKRIoTCarrier_Qtouch.h>
#include <Arduino_MKRIoTCarrier.h>
MKRIoTCarrier carrier;
// Initialize the MKR IoT Carrier and output any errors in the serial monitor
CARRIER_CASE = false;
carrier.begin();
carrier.display.setRotation(0);
carrier.leds.setPixelColor(2 , 0, 0, 125);
carrier.leds.show();
Yes, I really would try out that fix and instructions would be great!
Thanks!
Jean
OK, I’m going to ask you to provide some additional information that will allow me to provide you with exact instructions. Since you mentioned “Mac & PC”, I’m going to assume that you’re using the Arduino IDE. If not, please let me know.
Please do this:
  1. Select File > Preferences from the Arduino IDE’s menus.
  2. Check the box next to “Show verbose output during: [ ] compilation”.
  3. Click the OK button.
  4. Select Sketch > Verify/Compile from the Arduino IDE’s menus.
  5. Wait for the compilation to finish.
  6. Click on the black console pane at the bottom of the Arduino IDE window.
  7. Press Ctrl+A to select all the text.
  8. Press Ctrl+C to copy the selected text to the clipboard.
  9. Open a forum reply here by clicking the Reply button.
  10. Click the </> icon on the post composer toolbar. This will add the forum’s code block markup (```) to your reply to make sure the compilation output is correctly formatted.
    Code block
  11. Press Ctrl+V. This will paste the compilation output into the code block.
  12. Move the cursor outside of the code tags before you add any additional text to your reply.
  13. Click the Reply button to post the output.
Hello @pert !
yes, you are right - I´m using the IDE (the cloud editor did not work). Already tried the Github fix on Arduino_MKRIoTCarrier.h and now the LEDs are fine. :grinning:
Alright, here is the output from the compilation:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Jean\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Jean\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Jean\Documents\Arduino\libraries -fqbn=arduino:samd:mkrwifi1010 -vid-pid=2341_8054 -ide-version=10813 -build-path C:\Users\Jean\AppData\Local\Temp\arduino_build_156601 -warnings=none -build-cache C:\Users\Jean\AppData\Local\Temp\arduino_cache_650577 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.openocd.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.CMSIS.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.bossac.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -verbose C:\Users\Jean\Documents\Arduino\led-test\led-test.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Jean\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Jean\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Jean\Documents\Arduino\libraries -fqbn=arduino:samd:mkrwifi1010 -vid-pid=2341_8054 -ide-version=10813 -build-path C:\Users\Jean\AppData\Local\Temp\arduino_build_156601 -warnings=none -build-cache C:\Users\Jean\AppData\Local\Temp\arduino_cache_650577 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.openocd.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.CMSIS.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.bossac.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -verbose C:\Users\Jean\Documents\Arduino\led-test\led-test.ino
Using board 'mkrwifi1010' from platform in folder: C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.11
Using core 'arduino' from platform in folder: C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.11
Detecting libraries used...
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\variants\\mkrwifi1010" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\sketch\\led-test.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Arduino_MKRIoTCarrier_Qtouch.h: [Arduino_MKRIoTCarrier@0.9.7]
ResolveLibrary(Arduino_MKRIoTCarrier_Qtouch.h)
  -> candidates: [Arduino_MKRIoTCarrier@0.9.7]
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\variants\\mkrwifi1010" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MKRIoTCarrier\\src" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\sketch\\led-test.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Arduino_MCHPTouch.h: [Arduino_MCHPTouch@1.1.0]
ResolveLibrary(Arduino_MCHPTouch.h)
  -> candidates: [Arduino_MCHPTouch@1.1.0]
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\variants\\mkrwifi1010" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MKRIoTCarrier\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MCHPTouch\\src" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\sketch\\led-test.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\variants\\mkrwifi1010" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MKRIoTCarrier\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MCHPTouch\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\Wire" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\sketch\\led-test.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Arduino_PMIC.h: [Arduino_BQ24195@0.9.1]
ResolveLibrary(Arduino_PMIC.h)
  -> candidates: [Arduino_BQ24195@0.9.1]
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\variants\\mkrwifi1010" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MKRIoTCarrier\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MCHPTouch\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\Wire" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_BQ24195\\src" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\sketch\\led-test.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Arduino_APDS9960.h: [Arduino_APDS9960@1.0.3]
ResolveLibrary(Arduino_APDS9960.h)
  -> candidates: [Arduino_APDS9960@1.0.3]
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\variants\\mkrwifi1010" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MKRIoTCarrier\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MCHPTouch\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\Wire" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_BQ24195\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_APDS9960\\src" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\sketch\\led-test.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Arduino_LPS22HB.h: [Arduino_LPS22HB@1.0.1]
ResolveLibrary(Arduino_LPS22HB.h)
  -> candidates: [Arduino_LPS22HB@1.0.1]
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\variants\\mkrwifi1010" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MKRIoTCarrier\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MCHPTouch\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\Wire" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_BQ24195\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_APDS9960\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LPS22HB\\src" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\sketch\\led-test.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Arduino_LSM6DS3.h: [Arduino_LSM6DS3@1.0.0]
ResolveLibrary(Arduino_LSM6DS3.h)
  -> candidates: [Arduino_LSM6DS3@1.0.0]
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\variants\\mkrwifi1010" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MKRIoTCarrier\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MCHPTouch\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\Wire" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_BQ24195\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_APDS9960\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LPS22HB\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LSM6DS3\\src" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\sketch\\led-test.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\variants\\mkrwifi1010" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MKRIoTCarrier\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MCHPTouch\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\Wire" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_BQ24195\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_APDS9960\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LPS22HB\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LSM6DS3\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\SPI" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\sketch\\led-test.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Arduino_HTS221.h: [Arduino_HTS221@1.0.0]
ResolveLibrary(Arduino_HTS221.h)
  -> candidates: [Arduino_HTS221@1.0.0]
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\variants\\mkrwifi1010" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MKRIoTCarrier\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MCHPTouch\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\Wire" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_BQ24195\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_APDS9960\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LPS22HB\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LSM6DS3\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\SPI" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_HTS221\\src" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\sketch\\led-test.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SD.h: [SD@1.2.4]
ResolveLibrary(SD.h)
  -> candidates: [SD@1.2.4]
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\variants\\mkrwifi1010" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MKRIoTCarrier\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MCHPTouch\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\Wire" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_BQ24195\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_APDS9960\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LPS22HB\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LSM6DS3\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\SPI" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_HTS221\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\sketch\\led-test.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Adafruit_GFX.h: [Adafruit_GFX_Library@1.10.7]
ResolveLibrary(Adafruit_GFX.h)
  -> candidates: [Adafruit_GFX_Library@1.10.7]
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\variants\\mkrwifi1010" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MKRIoTCarrier\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MCHPTouch\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\Wire" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_BQ24195\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_APDS9960\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LPS22HB\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LSM6DS3\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\SPI" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_HTS221\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\sketch\\led-test.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Adafruit_ST7735.h: [Adafruit_ST7735_and_ST7789_Library@1.7.2]
ResolveLibrary(Adafruit_ST7735.h)
  -> candidates: [Adafruit_ST7735_and_ST7789_Library@1.7.2]
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\variants\\mkrwifi1010" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MKRIoTCarrier\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MCHPTouch\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\Wire" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_BQ24195\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_APDS9960\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LPS22HB\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LSM6DS3\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\SPI" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_HTS221\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\sketch\\led-test.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Adafruit_DotStar.h: [Adafruit_DotStar@1.1.4]
ResolveLibrary(Adafruit_DotStar.h)
  -> candidates: [Adafruit_DotStar@1.1.4]
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\variants\\mkrwifi1010" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MKRIoTCarrier\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MCHPTouch\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\Wire" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_BQ24195\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_APDS9960\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LPS22HB\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LSM6DS3\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\SPI" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_HTS221\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_DotStar" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\sketch\\led-test.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\variants\\mkrwifi1010" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MKRIoTCarrier\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MCHPTouch\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\Wire" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_BQ24195\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_APDS9960\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LPS22HB\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LSM6DS3\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\SPI" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_HTS221\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_DotStar" "C:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MKRIoTCarrier\\src\\Arduino_MKRIoTCarrier.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Arduino_MKRIoTCarrier\src\Arduino_MKRIoTCarrier_Buzzer.cpp
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Arduino_MKRIoTCarrier\src\Arduino_MKRIoTCarrier_Qtouch.cpp
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Arduino_MKRIoTCarrier\src\Arduino_MKRIoTCarrier_Relay.cpp
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Arduino_MCHPTouch\src\Arduino_MCHPTouch.cpp
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Arduino_MCHPTouch\src\touch.c
Using cached library dependencies for file: C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.11\libraries\Wire\Wire.cpp
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Arduino_BQ24195\src\BQ24195.cpp
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Arduino_APDS9960\src\Arduino_APDS9960.cpp
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Arduino_LPS22HB\src\BARO.cpp
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Arduino_LSM6DS3\src\LSM6DS3.cpp
Using cached library dependencies for file: C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.11\libraries\SPI\SPI.cpp
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Arduino_HTS221\src\HTS.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\libraries\SD\src\File.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\libraries\SD\src\SD.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\libraries\SD\src\utility\Sd2Card.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\libraries\SD\src\utility\SdFile.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\libraries\SD\src\utility\SdVolume.cpp
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_GrayOLED.cpp
Alternatives for Adafruit_I2CDevice.h: [Adafruit_BusIO@1.7.3]
ResolveLibrary(Adafruit_I2CDevice.h)
  -> candidates: [Adafruit_BusIO@1.7.3]
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_SPITFT.cpp
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Adafruit_GFX_Library\glcdfont.c
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library\Adafruit_ST7735.cpp
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library\Adafruit_ST7789.cpp
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library\Adafruit_ST77xx.cpp
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Adafruit_DotStar\Adafruit_DotStar.cpp
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp
Using cached library dependencies for file: C:\Users\Jean\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp
Generating function prototypes...
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\variants\\mkrwifi1010" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MKRIoTCarrier\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MCHPTouch\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\Wire" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_BQ24195\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_APDS9960\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LPS22HB\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LSM6DS3\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\SPI" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_HTS221\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_DotStar" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\sketch\\led-test.ino.cpp" -o "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Sketch wird kompiliert...
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\variants\\mkrwifi1010" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MKRIoTCarrier\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MCHPTouch\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\Wire" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_BQ24195\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_APDS9960\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LPS22HB\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LSM6DS3\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\SPI" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_HTS221\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_DotStar" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\sketch\\led-test.ino.cpp" -o "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\sketch\\led-test.ino.cpp.o"
Compiling libraries...
Compiling library "Arduino_MKRIoTCarrier"
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRWIFI1010 -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8054 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKR WiFi 1010\"" -DUSE_BQ24195L_PMIC "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\cores\\arduino" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\variants\\mkrwifi1010" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MKRIoTCarrier\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MCHPTouch\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\Wire" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_BQ24195\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_APDS9960\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LPS22HB\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_LSM6DS3\\src" "-IC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\libraries\\SPI" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_HTS221\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_ST7735_and_ST7789_Library" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_DotStar" "-IC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MKRIoTCarrier\\src\\Arduino_MKRIoTCarrier.cpp" -o "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Arduino_MKRIoTCarrier\\Arduino_MKRIoTCarrier.cpp.o"
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Arduino_MKRIoTCarrier\Arduino_MKRIoTCarrier_Relay.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Arduino_MKRIoTCarrier\Arduino_MKRIoTCarrier_Qtouch.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Arduino_MKRIoTCarrier\Arduino_MKRIoTCarrier_Buzzer.cpp.o
Compiling library "Arduino_MCHPTouch"
Library Arduino_MCHPTouch has been declared precompiled:
Using precompiled library in C:\Users\Jean\Documents\Arduino\libraries\Arduino_MCHPTouch\src\cortex-m0plus
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Arduino_MCHPTouch\touch.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Arduino_MCHPTouch\Arduino_MCHPTouch.cpp.o
Compiling library "Wire"
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Wire\Wire.cpp.o
Compiling library "Arduino_BQ24195"
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Arduino_BQ24195\BQ24195.cpp.o
Compiling library "Arduino_APDS9960"
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Arduino_APDS9960\Arduino_APDS9960.cpp.o
Compiling library "Arduino_LPS22HB"
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Arduino_LPS22HB\BARO.cpp.o
Compiling library "Arduino_LSM6DS3"
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Arduino_LSM6DS3\LSM6DS3.cpp.o
Compiling library "SPI"
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\SPI\SPI.cpp.o
Compiling library "Arduino_HTS221"
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Arduino_HTS221\HTS.cpp.o
Compiling library "SD"
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\SD\File.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\SD\SD.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\SD\utility\SdFile.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\SD\utility\Sd2Card.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\SD\utility\SdVolume.cpp.o
Compiling library "Adafruit_GFX_Library"
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Adafruit_GFX_Library\glcdfont.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Adafruit_GFX_Library\Adafruit_SPITFT.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Adafruit_GFX_Library\Adafruit_GrayOLED.cpp.o
Compiling library "Adafruit_ST7735_and_ST7789_Library"
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Adafruit_ST7735_and_ST7789_Library\Adafruit_ST7735.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Adafruit_ST7735_and_ST7789_Library\Adafruit_ST7789.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Adafruit_ST7735_and_ST7789_Library\Adafruit_ST77xx.cpp.o
Compiling library "Adafruit_DotStar"
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Adafruit_DotStar\Adafruit_DotStar.cpp.o
Compiling library "Adafruit_BusIO"
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp.o
Compiling core...
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\variant.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\pulse_asm.S.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\hooks.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\itoa.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\cortex_handlers.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\delay.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\WInterrupts.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\pulse.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\wiring.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\startup.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\wiring_analog.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\wiring_digital.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\compact\dtostrf.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\wiring_shift.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\wiring_private.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\USB\samd21_host.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\Reset.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\WMath.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\abi.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\Uart.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\SERCOM.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\Tone.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\new.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\api\Common.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\api\IPAddress.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\api\PluggableUSB.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\api\Print.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\api\Stream.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\api\String.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\main.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\USB\USBCore.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\USB\CDC.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Jean\AppData\Local\Temp\arduino_build_156601\core\core.a
Gebauter Kern wird archiviert (zwischengespeichert) in: C:\Users\Jean\AppData\Local\Temp\arduino_cache_650577\core\core_arduino_samd_mkrwifi1010_04c0df8d37d66efc2158b057c707a3d3.a
Linking everything together...
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" "-LC:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601" -Os -Wl,--gc-sections -save-temps "-TC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.11\\variants\\mkrwifi1010/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601/led-test.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601/led-test.ino.elf" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\sketch\\led-test.ino.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Arduino_MKRIoTCarrier\\Arduino_MKRIoTCarrier.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Arduino_MKRIoTCarrier\\Arduino_MKRIoTCarrier_Buzzer.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Arduino_MKRIoTCarrier\\Arduino_MKRIoTCarrier_Qtouch.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Arduino_MKRIoTCarrier\\Arduino_MKRIoTCarrier_Relay.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Arduino_MCHPTouch\\touch.c.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Arduino_MCHPTouch\\Arduino_MCHPTouch.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Arduino_BQ24195\\BQ24195.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Arduino_APDS9960\\Arduino_APDS9960.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Arduino_LPS22HB\\BARO.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Arduino_LSM6DS3\\LSM6DS3.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Arduino_HTS221\\HTS.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\SD\\File.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\SD\\SD.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\SD\\utility\\Sd2Card.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\SD\\utility\\SdFile.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\SD\\utility\\SdVolume.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Adafruit_GFX_Library\\glcdfont.c.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Adafruit_ST7735_and_ST7789_Library\\Adafruit_ST7735.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Adafruit_ST7735_and_ST7789_Library\\Adafruit_ST7789.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Adafruit_ST7735_and_ST7789_Library\\Adafruit_ST77xx.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Adafruit_DotStar\\Adafruit_DotStar.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp.o" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601\\core\\variant.cpp.o" "-LC:\\Users\\Jean\\Documents\\Arduino\\libraries\\Arduino_MCHPTouch\\src\\cortex-m0plus" -lsamd21_qt_gcc -lsamd21_qt_gcc -Wl,--start-group "-LC:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math -lm "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601/core\\core.a" -Wl,--end-group
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601/led-test.ino.elf" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601/led-test.ino.bin"
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601/led-test.ino.elf" "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601/led-test.ino.hex"
Bibliothek Arduino_MKRIoTCarrier in Version 0.9.7 im Ordner: C:\Users\Jean\Documents\Arduino\libraries\Arduino_MKRIoTCarrier  wird verwendet
Bibliothek Arduino_MCHPTouch in Version 1.1.0 im Ordner: C:\Users\Jean\Documents\Arduino\libraries\Arduino_MCHPTouch  wird verwendet
Bibliothek Wire in Version 1.0 im Ordner: C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.11\libraries\Wire  wird verwendet
Bibliothek Arduino_BQ24195 in Version 0.9.1 im Ordner: C:\Users\Jean\Documents\Arduino\libraries\Arduino_BQ24195  wird verwendet
Bibliothek Arduino_APDS9960 in Version 1.0.3 im Ordner: C:\Users\Jean\Documents\Arduino\libraries\Arduino_APDS9960  wird verwendet
Bibliothek Arduino_LPS22HB in Version 1.0.1 im Ordner: C:\Users\Jean\Documents\Arduino\libraries\Arduino_LPS22HB  wird verwendet
Bibliothek Arduino_LSM6DS3 in Version 1.0.0 im Ordner: C:\Users\Jean\Documents\Arduino\libraries\Arduino_LSM6DS3  wird verwendet
Bibliothek SPI in Version 1.0 im Ordner: C:\Users\Jean\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.11\libraries\SPI  wird verwendet
Bibliothek Arduino_HTS221 in Version 1.0.0 im Ordner: C:\Users\Jean\Documents\Arduino\libraries\Arduino_HTS221  wird verwendet
Bibliothek SD in Version 1.2.4 im Ordner: C:\Program Files (x86)\Arduino\libraries\SD  wird verwendet
Bibliothek Adafruit_GFX_Library in Version 1.10.7 im Ordner: C:\Users\Jean\Documents\Arduino\libraries\Adafruit_GFX_Library  wird verwendet
Bibliothek Adafruit_ST7735_and_ST7789_Library in Version 1.7.2 im Ordner: C:\Users\Jean\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library  wird verwendet
Bibliothek Adafruit_DotStar in Version 1.1.4 im Ordner: C:\Users\Jean\Documents\Arduino\libraries\Adafruit_DotStar  wird verwendet
Bibliothek Adafruit_BusIO in Version 1.7.3 im Ordner: C:\Users\Jean\Documents\Arduino\libraries\Adafruit_BusIO  wird verwendet
"C:\\Users\\Jean\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-size" -A "C:\\Users\\Jean\\AppData\\Local\\Temp\\arduino_build_156601/led-test.ino.elf"
Der Sketch verwendet 47280 Bytes (18%) des Programmspeicherplatzes. Das Maximum sind 262144 Bytes.
Globale Variablen verwenden 4604 Bytes (14%) des dynamischen Speichers, 28164 Bytes für lokale Variablen verbleiben. Das Maximum sind 32768 Bytes.
Great work! I’m glad to hear the colors are correct now. Hopefully this fix will be made accessible to everyone soon with a new release of the library.
Yes, it’s a bit confusing - especially when you’re just starting out, driving only one LED, and then the color isn’t right.
Thanks a lot for your help! That made my day!
