Hello!
When creating the demo project "Solar system tracker" (https://opla.arduino.cc/opla/module/iot-starter-kit-maker/lesson/04-solar-system-tracker) I don´t get the JSON data.
Output in monitor is:
Starting connection to server...
connected to server
HTTP/1.0 408 Request Time-out
Cache-Control: no-cache
Connection: close
Content-Type: text/html
The display of the device is pink with text "Update complete Data from: null"
I´ve already tried a lot but get no result.
Code is:
#include <WiFiNINA.h>
#include <Arduino_JSON.h>
#include <Arduino_MKRIoTCarrier.h>
MKRIoTCarrier carrier;
char ssid[] = "mywlan"; // your network SSID (name)
char pass[] = "***";// your network PASSWORD ()
String bodyName;
String planet;
String explorerName;
String explorerDate;
double gravity;
double density;
char *planets[] = {"jupiter", "io", "europe",
"callisto", "mars", "mercury",
"venus", "terre", "uranus", "neptune",
"saturne", "phoebe", "ganymede", "titan",
"pluton", "triton", "titania", "charon", "ariel",
"tethys", "protee"
int status = WL_IDLE_STATUS;
char server[] = "api.le-systeme-solaire.net";
WiFiClient client;
//Initialize serial and wait for port to open:
while (!Serial);
// attempt to connect to Wifi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
status = WiFi.begin(ssid, pass);
// wait 1 seconds for connection:
Serial.println("Connected to wifi");
//Initialize the carrier
CARRIER_CASE = false;
carrier.begin();
carrier.display.setRotation(0);
delay(100);
carrier.Buttons.update();
if (carrier.Button0.onTouchDown()) {
carrier.display.fillScreen(ST77XX_MAGENTA);
carrier.display.setCursor(30, 60);
carrier.display.setTextColor(ST77XX_WHITE);
carrier.display.setTextSize(2);
carrier.display.print("Searching");
carrier.display.print(".");
planetUpdate();
carrier.display.print("Update complete");
carrier.display.setCursor(20, 90);
carrier.display.print("Data from: ");
carrier.display.setCursor(20, 130);
carrier.display.print(bodyName);
if (carrier.Button1.onTouchDown()) {
carrier.display.fillScreen(ST77XX_RED);
carrier.display.setCursor(20, 60);
carrier.display.print("Is a moon of: ");
carrier.display.setCursor(20, 110);
carrier.display.println(planet);
if (carrier.Button2.onTouchDown()) {
carrier.display.fillScreen(ST77XX_GREEN);
carrier.display.print("Discovered by: ");
carrier.display.println(explorerName);
carrier.display.print("Date: ");
carrier.display.print(explorerDate);
if (carrier.Button3.onTouchDown()) {
carrier.display.fillScreen(ST77XX_BLUE);
carrier.display.print("Gravity is: ");
carrier.display.print(gravity);
carrier.display.print(" m/s2");
if (carrier.Button4.onTouchDown()) {
carrier.display.fillScreen(ST77XX_BLACK);
carrier.display.print("Density is: ");
carrier.display.print(density);
carrier.display.print(" g/cm3");
String line = "";
while (client.connected()) {
line = client.readStringUntil('\n');
Serial.println(line);
JSONVar myObject = JSON.parse(line);
bodyName = JSON.stringify(myObject["englishName"]);
planet = JSON.stringify(myObject["aroundPlanet"]["planet"]);
explorerName = JSON.stringify(myObject["discoveredBy"]);
explorerDate = JSON.stringify(myObject["discoveryDate"]);
gravity = myObject["gravity"];
density = myObject["density"];
delay(100);
if (line.startsWith("{")) {
void planetUpdate() {
int randomPlanet = random(0, 20);
Serial.println("\nStarting connection to server...");
Serial.println(server);
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println("connected to server");
// Make a HTTP request:
/* client.print("GET ");
client.print("/rest/bodies/");
client.print(planets[randomPlanet]);
client.println(" HTTP/1.0");*/
client.println("GET /rest/bodies/mars HTTP/1.0");
client.println("Host: api.le-systeme-solaire.net");
client.println("Connection: close");
client.println();
Serial.println("unable to connect");
Any idea what may cause this?
