--- Start compilation (OnSave) 18:48:22 ---
Created C:\Users\faaki\Documents\Ardruino Projects\Cloud test 10 04 2025\Cloud test 10 04 2025\Global shared.plc (0 vars)
Created C:\Users\faaki\Documents\Ardruino Projects\Cloud test 10 04 2025\Cloud test 10 04 2025\ParDB.plc
Created C:\Users\faaki\Documents\Ardruino Projects\Cloud test 10 04 2025\Cloud test 10 04 2025\IO.plc
Created C:\Users\faaki\Documents\Ardruino Projects\Cloud test 10 04 2025\Cloud test 10 04 2025\SharedVars.plc
--- End compilation (OnSave) 18:48:22 ---
--- Start compilation (PreBuild) 18:48:22 ---
--- End compilation (PreBuild) 18:48:22 ---
--- Start compilation (PostBuild) 18:48:22 ---
Sketch generated, is changed: true
C:\Program Files\Arduino PLC IDE Tools\arduino-cli.exe --config-file "C:\Users\faaki\AppData\Local\T\arduino-cli.yaml" compile "C:\Users\faaki\Documents\Ardruino Projects\Cloud test 10 04 2025\Cloud test 10 04 2025\LLSketch" -b arduino:mbed_opta:opta --build-path "C:\Users\faaki\Documents\Ardruino Projects\Cloud test 10 04 2025\Cloud test 10 04 2025\LLSketch_build" -v --profile opta_1.2.0
Downloading library ArduinoIoTCloud @2.4.1...
Library ArduinoIoTCloud @2.4.1 not found...
Error initializing instance: Library 'ArduinoIoTCloud ' not found
FQBN: arduino:mbed_opta:opta
Using board 'opta' from platform in folder: C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d
Using core 'arduino' from platform in folder: C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d
Detecting libraries used...
C:\Users\faaki\AppData\Local\T\A\internal\arduino_arm-none-eabi-gcc_7-2017q4_7b7be9f526b2cb64/bin/arm-none-eabi-g++ -c -w -g3 -nostdlib @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/defines.txt @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/cxxflags.txt -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_OPTA -DARDUINO_ARCH_MBED_OPTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA -DCM4_BINARY_START=0x60000000 -DCM4_BINARY_END=0x60040000 -DCM4_RAM_END=0x60080000 -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino/api/deprecated -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino/api/deprecated-avr-comp -iprefixC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/../OPTA/includes.txt C:\Users\faaki\Documents\Ardruino Projects\Cloud test 10 04 2025\Cloud test 10 04 2025\LLSketch_build\sketch\LLSketch.ino.cpp -o nul
Alternatives for AlPlc_Opta.h: [AlPlc_Opta@1.2.0]
ResolveLibrary(AlPlc_Opta.h)
-> candidates: [AlPlc_Opta@1.2.0]
C:\Users\faaki\AppData\Local\T\A\internal\arduino_arm-none-eabi-gcc_7-2017q4_7b7be9f526b2cb64/bin/arm-none-eabi-g++ -c -w -g3 -nostdlib @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/defines.txt @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/cxxflags.txt -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_OPTA -DARDUINO_ARCH_MBED_OPTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA -IC:\Users\faaki\AppData\Local\T\A\internal\AlPlc_Opta_1.2.0_6f942e4889808e7a\AlPlc_Opta\src -DCM4_BINARY_START=0x60000000 -DCM4_BINARY_END=0x60040000 -DCM4_RAM_END=0x60080000 -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino/api/deprecated -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino/api/deprecated-avr-comp -iprefixC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/../OPTA/includes.txt C:\Users\faaki\Documents\Ardruino Projects\Cloud test 10 04 2025\Cloud test 10 04 2025\LLSketch_build\sketch\LLSketch.ino.cpp -o nul
Alternatives for ArduinoRS485.h: [ArduinoRS485@1.0.5]
ResolveLibrary(ArduinoRS485.h)
-> candidates: [ArduinoRS485@1.0.5]
C:\Users\faaki\AppData\Local\T\A\internal\arduino_arm-none-eabi-gcc_7-2017q4_7b7be9f526b2cb64/bin/arm-none-eabi-g++ -c -w -g3 -nostdlib @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/defines.txt @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/cxxflags.txt -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_OPTA -DARDUINO_ARCH_MBED_OPTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA -IC:\Users\faaki\AppData\Local\T\A\internal\AlPlc_Opta_1.2.0_6f942e4889808e7a\AlPlc_Opta\src -IC:\Users\faaki\AppData\Local\T\A\internal\ArduinoRS485_1.0.5_a61cd3c6d72c41a3\ArduinoRS485\src -DCM4_BINARY_START=0x60000000 -DCM4_BINARY_END=0x60040000 -DCM4_RAM_END=0x60080000 -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino/api/deprecated -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino/api/deprecated-avr-comp -iprefixC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/../OPTA/includes.txt C:\Users\faaki\Documents\Ardruino Projects\Cloud test 10 04 2025\Cloud test 10 04 2025\LLSketch_build\sketch\LLSketch.ino.cpp -o nul
Alternatives for PortentaEthernet.h: [Ethernet@1.0.0]
ResolveLibrary(PortentaEthernet.h)
-> candidates: [Ethernet@1.0.0]
C:\Users\faaki\AppData\Local\T\A\internal\arduino_arm-none-eabi-gcc_7-2017q4_7b7be9f526b2cb64/bin/arm-none-eabi-g++ -c -w -g3 -nostdlib @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/defines.txt @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/cxxflags.txt -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_OPTA -DARDUINO_ARCH_MBED_OPTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA -IC:\Users\faaki\AppData\Local\T\A\internal\AlPlc_Opta_1.2.0_6f942e4889808e7a\AlPlc_Opta\src -IC:\Users\faaki\AppData\Local\T\A\internal\ArduinoRS485_1.0.5_a61cd3c6d72c41a3\ArduinoRS485\src -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\libraries\Ethernet\src -DCM4_BINARY_START=0x60000000 -DCM4_BINARY_END=0x60040000 -DCM4_RAM_END=0x60080000 -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino/api/deprecated -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino/api/deprecated-avr-comp -iprefixC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/../OPTA/includes.txt C:\Users\faaki\Documents\Ardruino Projects\Cloud test 10 04 2025\Cloud test 10 04 2025\LLSketch_build\sketch\LLSketch.ino.cpp -o nul
Alternatives for SocketHelpers.h: [SocketWrapper@1.0]
ResolveLibrary(SocketHelpers.h)
-> candidates: [SocketWrapper@1.0]
C:\Users\faaki\AppData\Local\T\A\internal\arduino_arm-none-eabi-gcc_7-2017q4_7b7be9f526b2cb64/bin/arm-none-eabi-g++ -c -w -g3 -nostdlib @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/defines.txt @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/cxxflags.txt -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_OPTA -DARDUINO_ARCH_MBED_OPTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA -IC:\Users\faaki\AppData\Local\T\A\internal\AlPlc_Opta_1.2.0_6f942e4889808e7a\AlPlc_Opta\src -IC:\Users\faaki\AppData\Local\T\A\internal\ArduinoRS485_1.0.5_a61cd3c6d72c41a3\ArduinoRS485\src -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\libraries\Ethernet\src -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\libraries\SocketWrapper\src -DCM4_BINARY_START=0x60000000 -DCM4_BINARY_END=0x60040000 -DCM4_RAM_END=0x60080000 -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino/api/deprecated -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino/api/deprecated-avr-comp -iprefixC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/../OPTA/includes.txt C:\Users\faaki\Documents\Ardruino Projects\Cloud test 10 04 2025\Cloud test 10 04 2025\LLSketch_build\sketch\LLSketch.ino.cpp -o nul
Alternatives for OptaBlue.h: [Arduino_Opta_Blueprint@0.2.2]
ResolveLibrary(OptaBlue.h)
-> candidates: [Arduino_Opta_Blueprint@0.2.2]
C:\Users\faaki\AppData\Local\T\A\internal\arduino_arm-none-eabi-gcc_7-2017q4_7b7be9f526b2cb64/bin/arm-none-eabi-g++ -c -w -g3 -nostdlib @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/defines.txt @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/cxxflags.txt -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_OPTA -DARDUINO_ARCH_MBED_OPTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA -IC:\Users\faaki\AppData\Local\T\A\internal\AlPlc_Opta_1.2.0_6f942e4889808e7a\AlPlc_Opta\src -IC:\Users\faaki\AppData\Local\T\A\internal\ArduinoRS485_1.0.5_a61cd3c6d72c41a3\ArduinoRS485\src -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\libraries\Ethernet\src -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\libraries\SocketWrapper\src -IC:\Users\faaki\AppData\Local\T\A\internal\Arduino_Opta_Blueprint_0.2.2_628e3ba029d0e5fe\Arduino_Opta_Blueprint\src -DCM4_BINARY_START=0x60000000 -DCM4_BINARY_END=0x60040000 -DCM4_RAM_END=0x60080000 -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino/api/deprecated -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino/api/deprecated-avr-comp -iprefixC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/../OPTA/includes.txt C:\Users\faaki\Documents\Ardruino Projects\Cloud test 10 04 2025\Cloud test 10 04 2025\LLSketch_build\sketch\LLSketch.ino.cpp -o nul
Alternatives for Wire.h: [Wire]
ResolveLibrary(Wire.h)
-> candidates: [Wire]
C:\Users\faaki\AppData\Local\T\A\internal\arduino_arm-none-eabi-gcc_7-2017q4_7b7be9f526b2cb64/bin/arm-none-eabi-g++ -c -w -g3 -nostdlib @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/defines.txt @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/cxxflags.txt -mcpu=cortex-m7 -mfloat-abi=softfp -mfpu=fpv5-d16 -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_OPTA -DARDUINO_ARCH_MBED_OPTA -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA -IC:\Users\faaki\AppData\Local\T\A\internal\AlPlc_Opta_1.2.0_6f942e4889808e7a\AlPlc_Opta\src -IC:\Users\faaki\AppData\Local\T\A\internal\ArduinoRS485_1.0.5_a61cd3c6d72c41a3\ArduinoRS485\src -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\libraries\Ethernet\src -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\libraries\SocketWrapper\src -IC:\Users\faaki\AppData\Local\T\A\internal\Arduino_Opta_Blueprint_0.2.2_628e3ba029d0e5fe\Arduino_Opta_Blueprint\src -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\libraries\Wire -DCM4_BINARY_START=0x60000000 -DCM4_BINARY_END=0x60040000 -DCM4_RAM_END=0x60080000 -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino/api/deprecated -IC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino/api/deprecated-avr-comp -iprefixC:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\cores\arduino @C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\variants\OPTA/../OPTA/includes.txt C:\Users\faaki\Documents\Ardruino Projects\Cloud test 10 04 2025\Cloud test 10 04 2025\LLSketch_build\sketch\LLSketch.ino.cpp -o nul
Alternatives for ArduinoIoTCloud.h: []
ResolveLibrary(ArduinoIoTCloud.h)
-> candidates: []
C:\Users\faaki\Documents\Ardruino Projects\Cloud test 10 04 2025\Cloud test 10 04 2025\LLSketch\LLSketch.ino:29:10: fatal error: ArduinoIoTCloud.h: No such file or directory
#include <ArduinoIoTCloud.h>
compilation terminated.
Used library Version Path
AlPlc_Opta 1.2.0 C:\Users\faaki\AppData\Local\T\A\internal\AlPlc_Opta_1.2.0_6f942e4889808e7a\AlPlc_Opta
ArduinoRS485 1.0.5 C:\Users\faaki\AppData\Local\T\A\internal\ArduinoRS485_1.0.5_a61cd3c6d72c41a3\ArduinoRS485
Ethernet 1.0.0 C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\libraries\Ethernet
SocketWrapper 1.0 C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\libraries\SocketWrapper
Arduino_Opta_Blueprint 0.2.2 C:\Users\faaki\AppData\Local\T\A\internal\Arduino_Opta_Blueprint_0.2.2_628e3ba029d0e5fe\Arduino_Opta_Blueprint
Wire C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d\libraries\Wire
Used platform Version Path
arduino:mbed_opta 4.1.6 C:\Users\faaki\AppData\Local\T\A\internal\arduino_mbed_opta_4.1.6_6bd5cf0253f43b1d
Error during build: exit status 1
