OPTA D1608E Output possible loads
Hey folks, recently bought the opta plc with a digital expansion module (EMR). The data sheet specifies that the relay load capacity is standard 250VAC/6A. This is well and good; however, I was wondering if I could connect a 24VDC from a power source on the COM side of the opta relay and a wire from NO to the positive input terminal of a 24VDC relay card. The negative input terminal is connected to the negative of the 24VDC supply. Will this work? My only intention is to isolate the opta relays.
Thanks in advance.
