Hi!
we are trying to use Opta Analog Exp' PWM for driving some heaters at a rather low frequency ~1Hz.
What we observed is that if PWM freq is set below ~50Hz, then PWW 2 and 3 stop working (do not output any signal) while commands getPwmFreqHz and getPwmPulsePerc still show that PWM 2 and 4 is active and PWM 1 and 4 will work fine.
PWM 1 and 4 work fine down to ~1Hz.
This behaviour was tested/could be recreated with standard PWM example code in IDE.
Has anyone observed such behaviour? is it a hardware limitation or some sort of a bug?
What is the lowest freq PWM Opta could handle? (haven't seen it documented anywhere)
Thanks!
