Optical endoder gives two steps
Hello,
I have bought an optical encoder like this :
To read it, I have tried this sketch :
 #define outputA 6
 #define outputB 7
 int counter = 0;
 int aState;
 int aLastState;
   pinMode (outputA,INPUT);
   pinMode (outputB,INPUT);
   Serial.begin (9600);
   // Reads the initial state of the outputA
   aLastState = digitalRead(outputA);
   aState = digitalRead(outputA); // Reads the "current" state of the outputA
   // If the previous and the current state of the outputA are different, that means a Pulse has occured
   if (aState != aLastState){
     // If the outputB state is different to the outputA state, that means the encoder is rotating clockwise
     if (digitalRead(outputB) != aState) {
       counter ++;
       counter --;
     Serial.print("Position: ");
     Serial.println(counter);
   aLastState = aState; // Updates the previous state of the outputA with the current state
It works well but the encoder bouton has some "clicks" (100 per revolution) and each click gives not one pulse but two, the console shows for the 1st one clik :
Position: 0
Position: 1
Then :
Position: 2
Position: 3
etc...
How can I divide by two, and have only one position change each click?
Thanks for your help
Code looks fine ...
How is the encoder connected?. Does it give sometimes 3 steps -insteado of two?. Or just one?. Does it behave different if you turn it quicker?.
Regards.
How is the encoder wired? Maybe you need to use pinMode(pin,INPUT_PULLUP) or a debounce library, or (last resort) interrupts.
https://www.pjrc.com/teensy/td_libs_Encoder.html
outsider:
Encoder Library, for Measuring Quadarature Encoded Position or Rotation Signals
I ask for the physical wiring (i mean, has it some filtering, or pull up's, ...). May be the problem is a bounce ...
Regards
Lots of encoders do that. The mechanical clicker has half as many steps as the electrical side. You may find that it always stops in a position where outputA is always HIGH.
Some encoders have a 1:4 ratio so they always stop with both outputs high.
The division operator is the forward-slash.
int realPosition = counter/2;
