I'm trying to use an optical mouse sensor ADNS-9800 to monitor the extrusion rate of clay coming out of a pug mill. I will use this extrusion rate to control the speed of cutting wires that cut custom parametric bricks.
I have the sensor giving me x and y data, which I cumulatively add and then use pythagorean theorem to get a total distance. The problem is that my readings depend heavily on the rate of motion. If I move the sensor 5cm in 1 second, the readings are around 1000 for total distance, but if i move it the same distance in 5 seconds, the reading is around 2500.
this is my code:
#include <SPI.h>
#include <avr/pgmspace.h>
// Registers
#define REG_Product_ID 0x00
#define REG_Revision_ID 0x01
#define REG_Motion 0x02
#define REG_Delta_X_L 0x03
#define REG_Delta_X_H 0x04
#define REG_Delta_Y_L 0x05
#define REG_Delta_Y_H 0x06
#define REG_SQUAL 0x07
#define REG_Pixel_Sum 0x08
#define REG_Maximum_Pixel 0x09
#define REG_Minimum_Pixel 0x0a
#define REG_Shutter_Lower 0x0b
#define REG_Shutter_Upper 0x0c
#define REG_Frame_Period_Lower 0x0d
#define REG_Frame_Period_Upper 0x0e
#define REG_Configuration_I 0x0f
#define REG_Configuration_II 0x10
#define REG_Frame_Capture 0x12
#define REG_SROM_Enable 0x13
#define REG_Run_Downshift 0x14
#define REG_Rest1_Rate 0x15
#define REG_Rest1_Downshift 0x16
#define REG_Rest2_Rate 0x17
#define REG_Rest2_Downshift 0x18
#define REG_Rest3_Rate 0x19
#define REG_Frame_Period_Max_Bound_Lower 0x1a
#define REG_Frame_Period_Max_Bound_Upper 0x1b
#define REG_Frame_Period_Min_Bound_Lower 0x1c
#define REG_Frame_Period_Min_Bound_Upper 0x1d
#define REG_Shutter_Max_Bound_Lower 0x1e
#define REG_Shutter_Max_Bound_Upper 0x1f
#define REG_LASER_CTRL0 0x20
#define REG_Observation 0x24
#define REG_Data_Out_Lower 0x25
#define REG_Data_Out_Upper 0x26
#define REG_SROM_ID 0x2a
#define REG_Lift_Detection_Thr 0x2e
#define REG_Configuration_V 0x2f
#define REG_Configuration_IV 0x39
#define REG_Power_Up_Reset 0x3a
#define REG_Shutdown 0x3b
#define REG_Inverse_Product_ID 0x3f
#define REG_Motion_Burst 0x50
#define REG_SROM_Load_Burst 0x62
#define REG_Pixel_Burst 0x64
byte initComplete = 0;
byte testctr = 0;
unsigned long currTime;
unsigned long timer;
unsigned long pollTimer;
volatile int xydat[2];
volatile byte movementflag = 0;
const int ncs = 10;
int long x = 0;
int long y = 0;
extern const unsigned short firmware_length;
extern const unsigned char firmware_data[];
pinMode (ncs, OUTPUT);
//attachInterrupt(0, UpdatePointer, FALLING);
SPI.begin();
SPI.setDataMode(SPI_MODE3);
SPI.setBitOrder(MSBFIRST);
SPI.setClockDivider(8);
performStartup();
Serial.println("ADNS9800testPolling");
dispRegisters();
delay(5000);
initComplete = 9;
void adns_com_begin() {
digitalWrite(ncs, LOW);
void adns_com_end() {
digitalWrite(ncs, HIGH);
byte adns_read_reg(byte reg_addr) {
adns_com_begin();
// send adress of the register, with MSBit = 0 to indicate it's a read
SPI.transfer(reg_addr & 0x7f );
delayMicroseconds(100); // tSRAD
// read data
byte data = SPI.transfer(0);
delayMicroseconds(1); // tSCLK-NCS for read operation is 120ns
adns_com_end();
delayMicroseconds(19); // tSRW/tSRR (=20us) minus tSCLK-NCS
return data;
void adns_write_reg(byte reg_addr, byte data) {
adns_com_begin();
//send adress of the register, with MSBit = 1 to indicate it's a write
SPI.transfer(reg_addr | 0x80 );
//sent data
SPI.transfer(data);
delayMicroseconds(20); // tSCLK-NCS for write operation
adns_com_end();
delayMicroseconds(100); // tSWW/tSWR (=120us) minus tSCLK-NCS. Could be shortened, but is looks like a safe lower bound
void adns_upload_firmware() {
// send the firmware to the chip, cf p.18 of the datasheet
Serial.println("Uploading firmware...");
// set the configuration_IV register in 3k firmware mode
adns_write_reg(REG_Configuration_IV, 0x02); // bit 1 = 1 for 3k mode, other bits are reserved
// write 0x1d in SROM_enable reg for initializing
adns_write_reg(REG_SROM_Enable, 0x1d);
// wait for more than one frame period
delay(10); // assume that the frame rate is as low as 100fps... even if it should never be that low
// write 0x18 to SROM_enable to start SROM download
adns_write_reg(REG_SROM_Enable, 0x18);
// write the SROM file (=firmware data)
adns_com_begin();
SPI.transfer(REG_SROM_Load_Burst | 0x80); // write burst destination adress
delayMicroseconds(15);
// send all bytes of the firmware
unsigned char c;
for (int i = 0; i < firmware_length; i++) {
c = (unsigned char)pgm_read_byte(firmware_data + i);
SPI.transfer(c);
adns_com_end();
void performStartup(void) {
adns_com_end(); // ensure that the serial port is reset
adns_com_begin(); // ensure that the serial port is reset
adns_write_reg(REG_Power_Up_Reset, 0x5a); // force reset
delay(50); // wait for it to reboot
// read registers 0x02 to 0x06 (and discard the data)
adns_read_reg(REG_Motion);
adns_read_reg(REG_Delta_X_L);
adns_read_reg(REG_Delta_X_H);
adns_read_reg(REG_Delta_Y_L);
adns_read_reg(REG_Delta_Y_H);
// upload the firmware
adns_upload_firmware();
delay(10);
//enable laser(bit 0 = 0b), in normal mode (bits 3,2,1 = 000b)
// reading the actual value of the register is important because the real
// default value is different from what is said in the datasheet, and if you
// change the reserved bytes (like by writing 0x00...) it would not work.
byte laser_ctrl0 = adns_read_reg(REG_LASER_CTRL0);
adns_write_reg(REG_LASER_CTRL0, laser_ctrl0 & 0xf0 );
delay(1);
Serial.println("Optical Chip Initialized");
void UpdatePointer(void) {
if (initComplete == 9) {
xydat[0] = (int)adns_read_reg(REG_Delta_X_L);
xydat[1] = (int)adns_read_reg(REG_Delta_Y_L);
//movementflag=1;
void dispRegisters(void) {
int oreg[7] = {
0x00, 0x3F, 0x2A, 0x02
char* oregname[] = {
"Product_ID", "Inverse_Product_ID", "SROM_Version", "Motion"
byte regres;
int rctr = 0;
for (rctr = 0; rctr < 4; rctr++) {
SPI.transfer(oreg[rctr]);
delay(1);
Serial.println("---");
Serial.println(oregname[rctr]);
Serial.println(oreg[rctr], HEX);
regres = SPI.transfer(0);
Serial.println(regres, BIN);
Serial.println(regres, HEX);
delay(1);
int convTwosComp(int b) {
//Convert from 2's complement
if (b & 0x80) {
b = -1 * ((b ^ 0xff) + 1);
return b;
currTime = millis();
if (currTime > timer) {
Serial.println(testctr++);
timer = currTime + 5000;
x = 0;
y = 0;
if (currTime > pollTimer) {
UpdatePointer();
xydat[0] = convTwosComp(xydat[0]);
xydat[1] = convTwosComp(xydat[1]);
if (xydat[0] != 0 || xydat[1] != 0) {
x = x + abs(xydat[0]);
y = y + abs(xydat[1]);
float Zpos = sqrt(x * x + y * y);
Serial.print("x = ");
Serial.print(x);
Serial.print(" | ");
Serial.print("y = ");
Serial.println(y);
Serial.print("dist = ");
Serial.println(Zpos);
pollTimer = currTime + 1;
Is there something in the code that could be causing this, or is it an inherent problem with optical mouse sensors?
thanks!
