Optical Tachometer on Pro Micro clone - code not working
Hi there! Completely new to Arduino.
I am building an optical tachometer using an IR sensor. The tacho works on an Arduino R3 board but I would like to use a pro-micro clone instead, the version I have is 5V 16MHz:
The code is based on the code from James Rovere's Easy Peasy Tachometer project (thanks very much) and works fine on an Arduino R3 using pin 2 as the sensor input. Here is the code:
// optical_tacho2 for Arduino R3
//delay turned to 1000ms
#include <Wire.h>
#include  <Adafruit_SSD1306.h>// You may have to edit library for 128x64,
//  default is  128 x 32.
#define OLED_WIDTH 128
#define OLED_HEIGHT 64
#define  OLED_ADDR   0x3C // A very common address for these displays.
Adafruit_SSD1306  display(OLED_WIDTH, OLED_HEIGHT);
float value=0;
float rev=0;
int  rpm;
int oldtime=0;
int time;
void isr()          //interrupt  service routine
rev++;
 display.begin(SSD1306_SWITCHCAPVCC,  OLED_ADDR);
 display.clearDisplay();
digitalWrite(2 ,HIGH);// Instead  of using a pull up resistor. Use pin 2 on arduino R3 board
attachInterrupt(0,isr,RISING);  //attaching the interrupt
void  loop()
delay(1000);// 1 second delay
detachInterrupt(0);           //detaches  the interrupt while calculating
time=millis()-oldtime;        //finds the time
rpm=(rev/time)*60000;         //calculates rpm
oldtime=millis();             //saves  the current time
rev=0;
  display.setTextSize(2);
  display.setTextColor(WHITE);
  display.setCursor(0, 0);// Vertical, Horizontal.
  display.println("RPM:");
  display.setCursor(0,25);
  display.println(rpm);
  display.display();
For the Pro-micro clone I have changed the IR sensor input pin to 4:
 optical_tacho3_for cheap board.
 Caution!! Use 5V 16MHz settings, else board gets bricked. Use the Arduino bookmarks folder to un-brick devices
 This is the tacho for the cheap pro-micro clone
 on COM22 (may change ports)
// digitalwrite pin changed to 4
#include <Wire.h>
float value=0;
float rev=0;
int  rpm;
int oldtime=0;
int time;
int sensor = 4;
rev++;
digitalWrite(4 ,HIGH);// Instead  of using a pull up resistor. Use pin 4 on clone
void  loop()
rev=0;
display.display();
However, when I upload the code to the pro-micro clone, I get a fixed value on the OLED of RPM: 57
Diagnosis so far:
  • Works fine on R3 board with the IR sensor connected to pin 2
  • Changing the Pro Micro board in IDE to Sparkfun Pro Micro, Adafruit 32U4 Breakout or Arduino Micro has no effect
  • Changing delay(1000) to delay(2000) halves the number displayed to RPM: 29
  • Changing attachInterrupt(0,isr,RISING); detachInterrupt(0); attachInterrupt(0,isr,RISING); to attachInterrupt(4,isr,RISING); detachInterrupt(4); attachInterrupt(4,isr,RISING); displays a fixed RPM: 0 on the OLED
Circuit diagram:
  • Red wire is VCC
  • Black wire is GND
  • Orange wire is SDA (pin 2)
  • Yellow Wire is SCL (pin 3)
  • Brown wire is IR sensor input to board (pin 4)
Many thanks for any help :grinning:
From the Pro Micro schematic, pin 4 equals PD4
Based on the datasheet, PD4 is not the INT0 pin.
Hi sterretje
Brilliant, thankyou. On the above schematic it looks like pin 3 is INT0. Am I correct?
So how would I have to modify the code to account for this? Apologies, very new to programming...
Is a way to attach the interrupt that might be "easy peasy" but is error-prone
No comments about which IO-pins are interrupt-capable
and as a fixed number you the user must take care of which IO-pin relates to interrupt 0
it is better to use
to attach the correct interrupt
best regards Stefan
You have a few options; start by consulting the datasheet of the 32U4 microcontroller if you haven't done so yet.
Next look at the microprocessor pins. There are 5 pins that can be used as external interrupt
PD0..PD3 and PE6. All those pins are broken out on the Pro Micro
Processor    Pro Micro
PD0/SCL      D3/SCL
PD1/SDA      D2/SDA
PD2/RXD1     D0/RX
PD3/TXD2     D1/TX
PE6/AIN0     D7
So make your choice of the ones that are still available and attach the correct interrupt number. Follow @StefanL38's advice for that.
@StefanL38 @sterretje
Thanks very much for your information and help with understanding the functions and pinout above. I will take a look this evening and let you know if i manage to get it working :grinning:
Do you know this funky coverversion of The Monster Mash ?
@StefanL38 brilliant :grinning:
Apologies guys, we have had a big storm here so I've been repairing fences all day. I will report back tomorrow with my tacho findings.
@sterretje @StefanL38
Thanks very much; problem solved!
I started by reloading the program onto my R3 with the following amendments as suggested:
digitalWrite(2 ,HIGH); //Instead  of using a pull up resistor. Use pin 2 on arduino R3 board
attachInterrupt(digitalPinToInterrupt(2),isr,RISING);  //attaching the interrupt
void  loop()
detachInterrupt(digitalPinToInterrupt(2));           //detaches  the interrupt while calculating
rev=0;
  display.display();
This worked fine, so I then used D7 on the micro clone:
As above, and success :grinning:. Now all I need is 4 wheels and reheat. Cheers all!
I'm surprised :wink: I suspect that that should have been
attachInterrupt(digitalPinToInterrupt(7),isr,RISING);
And that digitalWrite(2 ,HIGH) should have been digitalWrite(7 ,HIGH).
With that said, you should not use magic numbers for pins but rather use names as shown below.
const uint8_t interruptPin = 7;
digitalWrite(interruptPin ,HIGH)
attachInterrupt(digitalPinToInterrupt(interruptPin),isr,RISING);
That way you only have to change the pin number once and there is no chance that you forgot to change it somewhere.
@sterretje
Haha! Yes I meant that I changed it to pin 7.
Thanks for your help with the code grammar. I will experiment with assigning as you have described above. Cheers!
