OptiloaderBoard
it just happened that i have blown up some ATMega328s on a Breadboard due to too high Voltage on the Input. Shame on me!
Looking over the mess, i recognized that one of the ATMega was still sort of working, but i have destroyed digitalPin 0 (RX)…
Well, i have needed some new 328 with Bootloader, so i decided to build a Board around the “non-RX-Pin-328”, dedicated to “burn” the Optiloader Bootloader to factory-new ATMega328s. Not that i would need it every day (hopefully ;)), but just for fun. It is based on the OptiLoader sketch which can be found here: GitHub - WestfW/OptiLoader: Arduino sketch for burning new bootloaders
the PCB has the dimensoins of an Arduino-PCB, but ist neither a Arduino-Clone nor a Shield.
It supports 5V Power Supply via USB-B or a USB2SERIAL compatible FTDI-Style 6pin header, which also allows Serial communication for monitoring.
If you solder in C1, the autoReset functionality for the 6pin header is enabled, which would even allow to upload a sketch to the Master ATMega via USB2SERIAL.
To support feedback during the progress without Serial Communication, i have added a Power-ON statusLED for the Master ant the Target, a ERROR-LED and one for each function called in the loop() of the OptiLoadersketch.
I have soldered a basic 28pin socket for the Target ATMega on my PCB, but there shoud be enough space to use a 28pin ZIF Socket ;).
If anyone is interested, i have attached the Eagle files. Feel free to use it, reproduce it or modify it, but it would be great if you leave some feedback :wink:
The Optiloader sketch needs to be a little bit modified inside the setup() and loop() in order to control the LEDs to something like the following:
void setup () {
  Serial.begin(19200); 			/* Initialize serial for status msgs */
  pinMode(13, OUTPUT); 			/* Blink the pin13 LED a few times */
  pulse(13,20);
  pinMode(A0, OUTPUT);
  pinMode(A1, OUTPUT);
  pinMode(A2, OUTPUT);
  pinMode(A3, OUTPUT);
  pinMode(A4, OUTPUT);
  pinMode(A5, OUTPUT);
void loop (void) {
  boolean error = false;
  fp("\nOptiLoader Bootstrap programmer.\n2011 by Bill Westfield (WestfW)\n\n");
  if (target_poweron()) {		/* Turn on target power */
    do {
     if (!target_identify()){ 		/* Figure out what kind of CPU */
       error = true;
     } else digitalWrite(A5, HIGH);
     if (!target_findimage()){		/* look for an image */
       error = true;
     } else digitalWrite(A4, HIGH);
     if (!target_progfuses()){		/* get fuses ready to program */
       error = true;
     } else digitalWrite(A3, HIGH);
     if (!target_program()){ 		/* Program the image */
       error = true;
     } else digitalWrite(A2, HIGH);
      (void) target_normfuses(); 	/* reset fuses to normal mode */
      digitalWrite(A1, HIGH);
   while (0);
  else {
   error = true;
 target_poweroff(); 			/* turn power off */
  digitalWrite(A0, error);
  fp ("\nType 'G' or hit RESET for next chip\n")
    while (1) {
      if (Serial.read() == 'G'){
        digitalWrite(A5, LOW);
        digitalWrite(A4, LOW);
        digitalWrite(A3, LOW);
        digitalWrite(A2, LOW);
        digitalWrite(A1, LOW);
        digitalWrite(A0, LOW);
i know, the Hardware could be optimized. A polyfuse to protect the USB port would be nice. I think it would be not that bad to power the target 328 throug a transistor istead of the Master digital Pin 9, and the next time i would etch the PCB with bigger Pads for the Resistors , LEDs and Capacitors… :roll_eyes:
but after all… it is working! 8)
OptiloaderBoard 001.zip (54 KB)
