Optimisation of 2 wired Arduino's, each with a LOL Led Shield and Touch Screen
Hi!
It took me a while to get this working.
I have 2 Arduino's communicating through i2c. Each has a LOL Led Shield and a Touch Screen. As one touches the screen it is both reflected on the directly connected Arduino as well as its sibling. Same goes for the other one.
I would love some help optimising the "drawing" of the LED's in the Loop, as it acts a bit sluggish sometimes. This could be due to the processor, but maybe also my newb code.
Thank you!
 #include <Charliplexing.h>
#include <TouchScreen.h>
#include <Wire.h>
#define Y1 A0 // YM
#define X2 A1 // XP
#define Y2 A2 // YP
#define X1 A3 // XM
#define MINPRESSURE 10
#define MAXPRESSURE 1000
const uint8_t rows = 14;
const uint8_t cols = 9;
const bool master = true;
int radius;
int x0,y0,z0; //incoming values
int x1,y1,z1; //incoming values
int brightness;
TouchScreen ts = TouchScreen(X2, Y2, X1, Y1, 300);
struct Point {
	byte brightness;
} points[rows][cols];
    LedSign::Init(GRAYSCALE);
	LedSign::SetBrightness(100);
	if (master) {
		Wire.begin();
		Wire.begin(5);
		Wire.onReceive(receiveEvent);
	TSPoint p = ts.getPoint();
	if (p.z > ts.pressureThreshhold) {
		x0 = map(p.x,920,140,0,rows*100);
		y0 = map(p.y,300,820,0,(cols+1)*100);
		z0 = map(p.z,300,200,1,7);
	Wire.beginTransmission(5);
	Wire.write(x0);
	Wire.write(y0);
	Wire.write(z0);
	Wire.endTransmission();
	int radius = pow(z0,2);
	for (uint8_t x = 0; x < rows; x++) {
		for (uint8_t y = 0; y < cols; y++) {
			if (radius > 100) {
				//int dist = abs((x*100)-x0)+abs((y*100)-y0);
				int dist = sqrt(pow((x*100)-x0,2)+pow((y*100)-y0,2));
				if (dist < radius) {
					brightness = map(dist,0,radius,7,1);
					points[x][y].brightness = brightness;
					LedSign::Set(x,y,brightness);
				} else if (points[x][y].brightness > 0) {
					LedSign::Set(x,y,--points[x][y].brightness);
	delay(10);
void receiveEvent(int howMany) {
	while (Wire.available()) {
		x1 = Wire.read();
		y1 = Wire.read();
		z1 = Wire.read();
	Wire.write(x0);
	Wire.write(y0);
	Wire.write(z0);
If there was a button press, get the x0, y0, z0 values. Then, regardless of whether the user did anything, or not, send the values. Please explain why.
Look at the documentation for the pow() function. Then, go look at the source code for the pow() function. Then, explain why
int radius = z0 * z0;
isn't a better idea.
			if (radius > 100) {
Test the radius first, ONE time, not deep in nested loops.
More wasteful, incorrect, calls to pow().
	delay(10);
Why?
Why am I not surprised?
		/*Wire.beginTransmission(5);
		Wire.write(x0);
		Wire.write(y0);
		Wire.write(z0);
		Wire.endTransmission();*/
Why is this now commented out?
Why are you doing anything if the touch screen isn't touched?
Some intermediate variables would be useful:
      int dx = x*100 - x0;
      int dy = y*100 - y0;
      int dist = sqrt(dx * dx + dy * dy);
					brightness = map(dist,0,z0,7,1);
Doing this
I would need to maybe mention also that the two Arduinos communicate with each other so one should be able to receive signals from B while no pressure is being applied to A.
Nothing in the code you posted reads what the other Arduino writes to the I2C pins.
