Optimising repetitive code
I was wondering if anyone could help out with some optimising tips for repetitive code?
In my project I have alot of code that looks like this:
       bitWrite(i, 0, j);
       bitWrite(i, 1, k);
       bitWrite(i, 2, l);
       bitWrite(i, 3, m);
       bitWrite(i, 4, n);
       bitWrite(i, 5, o);
       bitWrite(i, 6, p);
       bitWrite(i, 7, q);
Would using a for loop be more efficient for memory? With this example bit of code I want to set the individual bit values and move on but does the fact that I am address different bits with variables limit me to this direct style of coding?
Any pointers would be great, Thanks in advance !
Pointers… no, you don’t want pointers yet :stuck_out_tongue:
Arrays are your friend. Instead of a, b, c, d, e etc, use bitVal[0], bitVal[1] bitVal[2] etc, or in a loop:
byte val = 0;
byte bitVal[8] = {1, 0, 0, 1, 1, 1, 0, 1};
for (byte i = 0; i < 8; i++) {
  bitWrite(val, i, bitVal[i]);
Check the memory used after compiling your code. Make your changes then check new memory used again.
majenko:
byte val = 0;
Haha, yes, pointers was a bad choice of phrasing !
Thank you very much that is very interesting and actually brings up another point -
In my arrays in my code I have declared variables for every possible array location so that I could overwrite them later. Is this unnecessary? Can I initialize an array with all 0’s or 1’s for instance then overwrite it later in the code?
So this…
byte a1 = 0;
byte a2 = 0;
byte a3 = 0;
byte a4 = 0;
byte a5 = 0;
byte a6 = 0;
byte a7 = 0;
byte a8 = 0;
byte a9 = 0;
byte a10 = 0;
byte a11 = 0;
byte a12 = 0;
byte myArray [2][3][2] =
  {//Bank 1
    {A1, A2},
    {A3, A4},
    {A5, A6}
  {//Bank 2
    {A7, A8},
    {A9,A10},
    {A11,A12}
A1 = 1;
Becomes:
  {//Bank 1
    {0, 0},
    {0, 0},
    {0, 0}
  {//Bank 2
    {0, 0},
    {0, 0},
    {0, 0}
MyArray [0][0][0] = 1;
I will test this out but I imagine skipping all of those extra global variables will save me a fair bit of memory or will the compiler create a ‘variable’ each time I reference a point in the array during my main loop and result in the same memory useage?
One more thing, if I am saving the array contents to EEPROM can I still: initialize the array globally, then write code to load previously saved initial values from EEPROM in the setup(){} function?
Edited: for clarity.
if you need to split a number in bits that can be done in the loop too
byte val = 0;
byte bitVal = 42;
  bitWrite(val, i, bitVal & ( 1 << i) );  // 1 << i  creates a bit mask that is  1,2,4,8,16,32,...
