Optimization
Hello,
I am developing an arduino web server using the CC3000 adafruit wifi shield (actually a counterfeit without the jumpers needed for the mega). When I compile it for the uno, the compiler warns me that “stability problems may occur” because my memory is full. Do you guys have any idea on how to optimize it further? My code is below:
#include <SdFat.h>
#include <Adafruit_CC3000.h>
#include <SPI.h>
#include "utility/debug.h"
#include "utility/socket.h"
#define Adafruit_CC3000_IRQ   3
#define Adafruit_CC3000_VBAT  5
#define Adafruit_CC3000_CS    10
Adafruit_CC3000 cc3000 = Adafruit_CC3000(Adafruit_CC3000_CS, Adafruit_CC3000_IRQ, Adafruit_CC3000_VBAT, SPI_CLOCK_DIVIDER);
const char WLANSSID[] PROGMEM = "6T4MK";
const char WLANPASS[] PROGMEM = "YCX6HKPRKLZVNYSH";
#define WLANSECURITY   WLAN_SEC_WPA2
#define LISTENPORT 80
Adafruit_CC3000_Server server(LISTENPORT);
#define FILENAMELEN  20
#define HTTPInvalid   0
#define HTTPGET       1
#define HTTPPOST      2
#define FTHTML       0
#define FTICON       1
#define FTCSS        2
#define FTJAVASCRIPT 3
#define FTJPG        4
#define FTPNG        5
#define FTGIF        6
#define FTTEXT       7
#define FTINVALID    8
#define PINETHSPI   10
SdFat SD;
  while (!Serial) {
  Serial.println(F("Starting..."));
  SD.begin(4);
  if (!cc3000.begin()) {
    Serial.println(F("Shield inserted improperly"));
    while(1);
  Serial.println(F("Stage 1 of 2 complete"));
  if (!cc3000.connectToAP(WLANSSID, WLANPASS, WLANSECURITY)) {
    Serial.println(F("Failed!"));
    while(1);
  Serial.println(F("Stage 2 of 2 complete"));
  while (!cc3000.checkDHCP()) {
    delay(100);
  while (!displayConnectionDetails()) {
  server.begin();
  Serial.println(F("Server ready"));
  Adafruit_CC3000_ClientRef client = server.available();
  if (client) {
    while (client.connected()) {
      if (ServiceClient(&client)) {
    delay(1);
    client.stop();
bool ServiceClient(Adafruit_CC3000_ClientRef *client) {
  static boolean currentLineIsBlank = true;
  char clChar;
  File webFile;
  char fileName[FILENAMELEN + 1] = {0};
  char httpReqType = 0;
  char reqFileType = FTINVALID;
  const char *fileTypes[] = {"text/html", "image/x-icon", "text/css", "application/javascript", "image/jpeg", "image/png", "image/gif", "text/plain"};
  static char reqLine_1[40] = {0};
  static unsigned char reqLineIndex = 0;
  static bool gotLine_1 = false;
  if (client->available()) {
    clChar = client->read();
    if ((reqLineIndex < 39) && (gotLine_1 == false)) {
      if ((clChar != '\r') && (clChar != '\n')) {
        reqLine_1[reqLineIndex] = clChar;
        reqLineIndex++;
      else {
        gotLine_1 = true;
        reqLine_1[39] = 0;
    if ((clChar == '\n') && currentLineIsBlank) {
      httpReqType = accessFile(reqLine_1, fileName, &reqFileType);
      if (httpReqType == HTTPGET) {
        if (reqFileType < FTINVALID) {
          webFile = SD.open(fileName);
          if (webFile) {
            client->println(F("HTTP/1.1 200 OK"));
            client->print(F("Content-Type: "));
            client->println(fileTypes[reqFileType]);
            client->println(F("Connection: close"));
            client->println();
            while(webFile.available()) {
              int numBytesRead;
              char byteBuffer[64];
              numBytesRead = webFile.read(byteBuffer, 64);
              client->write(byteBuffer, numBytesRead);
            webFile.close();
          else {
            Serial.println(F("File cannot be opened"));
        else {
          // invalid file type
      else if (httpReqType == HTTPPOST) {
        // a POST HTTP request was received
      else {
        // unsupported HTTP request received
      reqLine_1[0] = 0;
      reqLineIndex = 0;
      gotLine_1 = false;
      return 1;
    if (clChar == '\n') {
    else if (clChar != '\r') {
      currentLineIsBlank = false;
  }  // if (client.available())
  return 0;
char accessFile(char *reqLine, char *fileName, char *fileType) {
  char requestType = HTTPInvalid;  // 1 = GET, 2 = POST. 0 = invalid
  char *strToken;
  *fileType = FTINVALID;
  strToken =  strtok(reqLine, " ");
  if (strcmp(strToken, "GET") == 0) {
    requestType = HTTPGET;
    strToken =  strtok(NULL, " ");
    if (strcmp(strToken, "/") == 0) {
      strcpy(fileName, "index.html");
      *fileType = FTHTML;
    else if (strlen(strToken) <= FILENAMELEN) {
      strcpy(fileName, strToken);
      strToken = strtok(strToken, ".");
      strToken = strtok(NULL, ".");
      if      (strcmp(strToken, "html") == 0) {*fileType = 0;}
      else if (strcmp(strToken, "ico") == 0) {*fileType = 1;}
      else if (strcmp(strToken, "css") == 0) {*fileType = 2;}
      else if (strcmp(strToken, "js")  == 0) {*fileType = 3;}
      else if (strcmp(strToken, "jpg") == 0) {*fileType = 4;}
      else if (strcmp(strToken, "png") == 0) {*fileType = 5;}
      else if (strcmp(strToken, "gif") == 0) {*fileType = 6;}
      else if (strcmp(strToken, "txt") == 0) {*fileType = 7;}
      else {*fileType = 8;}
    else {
  else if (strcmp(strToken, "POST") == 0) {
    requestType = HTTPPOST;
  return requestType;
bool displayConnectionDetails() {
  uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
  if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv)) {
    Serial.println(F("Unable to retrieve the IP Address!\r\n"));
    return false;
  else {
    Serial.print(F("\nIP Addr: ")); cc3000.printIPdotsRev(ipAddress);
    return true;
I already replaced SD with SDFat, and F()ed everything.
Thanks!
You can also use the strxxx_P variants. That will save a little more RAM for those double- quoted strings.
