Optimizing Code for speed
Hello,
I've been working on developing a digital vehicle sensor that replaces an old analog one using the arduino. Attached the block diagram and actual photo of my setup.
At a high level my code needs to do the following:
Read the angle from the magnetic sensor
Based on the angle calculate what the output voltage should be (lookup table)
Tell the DAC what voltage to output
I was able to get the code working, the output voltage tracks as expected, i would just like to work on optimizing it for speed.
Here is what i've done thus far:
\ out all of the serial lines
Switched the "DigitalWrites" of the clock syncs to either PORTB &= ~_BV(PB2) or PORTB |= _BV(PB2);
I struggled through the SPI portion of this code initially and still believe there is a lot of cleanup i can do. Originally i had the code such that it reads angle, temp and magnetic strength from the sensor. Now all i really need is to get the angle but i'm not really sure how to go about doing that.
Prior to me making any of the above optimization changes, I was able to hook my device up to an oscilloscope. In the installed configuration, the magnetic is tied to a shaft that is spring loaded. Thus I was able to rotate the magnet to "full open" and let the spring rotate it back. Here is the drop in voltage as the spring is rotating the shaft back. It seems from this that it is taking ~12ms for the device to adjust voltage.
Any thoughts? code on next reply due to size.
#include <Wire.h>
#include <Adafruit_MCP4725.h>
#include <SPI.h>
#define kNOERROR 0
#define kPRIMARYREADERROR 1
#define kEXTENDEDREADTIMEOUTERROR 2
#define kPRIMARYWRITEERROR 3
#define kEXTENDEDWRITETIMEOUTERROR 4
#define kCRCERROR 5
#define kUNABLETOCHANGEPROCESSORSTATE 6
//190907const uint16_t LEDPin = 13;
const uint32_t WRITE = 0x40;
const uint32_t READ = 0x00;
const uint32_t COMMAND_MASK = 0xC0;
const uint32_t ADDRESS_MASK = 0x3F;
unsigned long nextTime;
bool ledOn = false;
bool includeCRC = true;
uint16_t angle;
uint16_t temperature;
uint16_t fieldStrength;
float angleDegrees;
float temperatureC;
float fieldStrengthGauss;
const int sensorPin = A1;    // select the input pin for the input voltage
float sensorVoltage = 0;
float outputVoltage = 0;
Adafruit_MCP4725 dac;
//Code below is to read Vin, which will be used later as the "reference voltage" for the DAC
long readVcc() {
  // Read 1.1V reference against AVcc
  // set the reference to Vcc and the measurement to the internal 1.1V reference
  #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
    ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
  //#elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
     ADMUX = _BV(MUX5) | _BV(MUX0) ;
  #else
    ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
  #endif
  delay(2); // Wait for Vref to settle
  ADCSRA |= _BV(ADSC); // Start conversion
  while (bit_is_set(ADCSRA,ADSC)); // measuring
  uint8_t low  = ADCL; // must read ADCL first - it then locks ADCH
  uint8_t high = ADCH; // unlocks both
  long result = (high<<8) | low;
  result = 1105300L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
  return result; // Vcc in millivolts
void setup(void) {
  while (!Serial);
  Serial.println("Hello!");
  uint16_t unused;
  uint32_t flags;
  uint16_t angle;
  uint32_t flagsAndZeroOffset;
  // Initialize SPI
  SPI.begin();
  pinMode(SS, OUTPUT);
  //Sets Unused Pins to Internal Pullup
  pinMode(2,INPUT_PULLUP);
  pinMode(3,INPUT_PULLUP);
  pinMode(4,INPUT_PULLUP);
  pinMode(5,INPUT_PULLUP);
  pinMode(6,INPUT_PULLUP);
  pinMode(7,INPUT_PULLUP);
  pinMode(8,INPUT_PULLUP);
  pinMode(9,INPUT_PULLUP);
  pinMode(15,INPUT_PULLUP);
  pinMode(16,INPUT_PULLUP);
  pinMode(17,INPUT_PULLUP);
 //190907 pinMode(LEDPin, OUTPUT);
  nextTime = millis();
  //190907digitalWrite(LEDPin, LOW);
  digitalWrite(SS, HIGH);
  // Make sure all of the SPI pins are
  // ready by doing a read
  PrimaryRead(SS, 0x0, unused);
  // Unlock the device
  ExtendedWrite(SS, 0xFFFE, 0x27811F77);
  // Make sure the device is unlocked
  ExtendedRead(SS, 0x22, flags);
  if (!((flags & 0x0022) == 0x0020))
  Serial.println("Device is not Unlocked");
  // For Adafruit MCP4725A1 the address is 0x62 (default) or 0x63 (ADDR pin tied to VCC)
 dac.begin(0x62);
    TWBR = ((F_CPU /400000l) - 16) / 2; // Change the i2c clock to 400KHz
void loop(void) {
  if (PrimaryRead(SS, 0x20, angle) == kNOERROR)
        angleDegrees = (float)(angle & 0x0FFF) * (360.0 / 4096.0);
        if (CalculateParity(angle))
       //   Serial.print("Angle = ");
      //    Serial.print(angleDegrees);
       //   Serial.println(" Degrees");
      //    Serial.println("Parity error on Angle read");
    //    Serial.println("Unable to read Angle");
// This is the lookup table I use to tell the DAC how much voltage to output
// Angle From Sensor on left // Corresponding Desired Output Voltage on right
float array[8] = {
0, 3267,
29, 4785,
287, 265,
360, 3267,
if (angleDegrees<= array[0])
  outputVoltage = dac.setNearestActualVoltage(array[1], sensorVoltage, false);
 // Serial.println("Your below the bottom end of the table");
else if (angleDegrees >= array[6])
  outputVoltage = dac.setNearestActualVoltage(sensorVoltage, sensorVoltage, false);
//  Serial.println("Your above the top end of the table");
int x;
  for (x= 0; x<8; x=x+2){
  if (angleDegrees >=array[x]
&& angleDegrees <=array[x+2])
        outputVoltage = dac.setNearestActualVoltage((array[x+1] + ( (array[x+3] - array[x+1]) * ( (angleDegrees - array[x]
) / (array[x+2] - array[x]
) ) )),sensorVoltage, false);
//Serial.println("The Output Voltage is:  ");
//Serial.println(outputVoltage);
uint16_t PrimaryRead(uint16_t cs, uint16_t address, uint16_t& value)
uint16_t command;
if (!includeCRC)
uint8_t crcValue;
uint8_t crcCommand;
SPI.beginTransaction(SPISettings(1000000, MSBFIRST, SPI_MODE3));
// Combine the register address and the command into one byte
command = ((address & ADDRESS_MASK) | READ) << 8;
crcCommand = CalculateCRC(command);
// take the chip select low to select the device
PORTB &= ~_BV(PB2);
// send the device the register you want to read
SPI.transfer16(command);
SPI.transfer(crcCommand);
PORTB |= _BV(PB2);
PORTB &= ~_BV(PB2);
// send the command again to read the contents
value = SPI.transfer16(command);
crcValue = SPI.transfer(crcCommand);
// take the chip select high to de-select
PORTB |= _BV(PB2);
// Restore the 8 bit description
SPI.endTransaction();
// Check the CRC value
if (CalculateCRC(value) != crcValue)
//Serial.println("Calculated CRC = ");
//Serial.println(+ CalculateCRC(value));
//Serial.println("crcValue = ");
//Serial.println(crcValue);
return kCRCERROR;
PORTB &= ~_BV(PB2);
PORTB |= _BV(PB2);
PORTB &= ~_BV(PB2);
PORTB |= _BV(PB2);
return kNOERROR;
* PrimaryRead
* Read from the primary serial registers
void PrimaryRead(uint16_t cs, uint16_t* addresses, uint16_t* values, uint16_t* errors, uint16_t numberOfItems)
uint16_t command;
if (includeCRC)
uint8_t crcValue;
uint8_t crcCommand;
// to send 4 bits
command = ((addresses[0] & ADDRESS_MASK) | READ) << 8;
PORTB &= ~_BV(PB2);
PORTB |= _BV(PB2);
for (int index = 0; index < (numberOfItems - 1); ++index)
command = ((addresses[index + 1] & ADDRESS_MASK) | READ) << 8;
PORTB &= ~_BV(PB2);
values[index] = SPI.transfer16(command);
PORTB |= _BV(PB2);
// Check the CRC of the read value
if (CalculateCRC(values[index]) != crcValue)
errors[index] = kCRCERROR;
errors[index] = kNOERROR;
PORTB &= ~_BV(PB2);
values[numberOfItems - 1] = SPI.transfer16(command);
PORTB |= _BV(PB2);
if (CalculateCRC(values[numberOfItems - 1]) != crcValue)
errors[numberOfItems - 1] = kCRCERROR;
errors[numberOfItems - 1] = kNOERROR;
PORTB &= ~_BV(PB2);
PORTB |= _BV(PB2);
PORTB &= ~_BV(PB2);
PORTB |= _BV(PB2);
PORTB &= ~_BV(PB2);
PORTB |= _BV(PB2);
* PrimaryWrite
* Write to the primary serial registers
uint16_t PrimaryWrite(uint16_t cs, uint16_t address, uint16_t value)
uint16_t command;
if (includeCRC)
uint8_t crcCommand;
command = (((address & ADDRESS_MASK) | WRITE) << 8) | ((value >> 8) & 0x0FF);
// take the chip select low to select the device:
PORTB &= ~_BV(PB2);
SPI.transfer16(command); // Send most significant byte of register data
SPI.transfer(crcCommand); // Send the crc
// take the chip select high to de-select:
PORTB |= _BV(PB2);
command = ((((address + 1) & ADDRESS_MASK) | WRITE) << 8 ) | (value & 0x0FF);
PORTB &= ~_BV(PB2);
SPI.transfer16(command); // Send least significant byte of register data
PORTB |= _BV(PB2);
PORTB &= ~_BV(PB2);
PORTB |= _BV(PB2);
command = ((((address + 1) & ADDRESS_MASK) | WRITE) << 8) | (value & 0x0FF);
PORTB &= ~_BV(PB2);
PORTB |= _BV(PB2);
return kNOERROR;
* PrimaryWrite
void PrimaryWrite(uint16_t cs, uint16_t* addresses, uint16_t* values, uint16_t* errors, uint16_t numberOfItems)
uint16_t command;
if (includeCRC)
uint8_t crcCommand;
for (int index = 0; index < numberOfItems; ++index)
command = (((addresses[index] & ADDRESS_MASK) | WRITE) << 8) | ((values[index] >> 8) & 0x0FF);
PORTB &= ~_BV(PB2);
PORTB |= _BV(PB2);
command = ((((addresses[index] + 1) & ADDRESS_MASK) | WRITE) << 8 ) | (values[index] & 0x0FF);
PORTB &= ~_BV(PB2);
PORTB |= _BV(PB2);
PORTB &= ~_BV(PB2);
PORTB |= _BV(PB2);
PORTB &= ~_BV(PB2);
PORTB |= _BV(PB2);
* ExtendedRead
* Read from the SRAM, EEPROM, AUX or Extended Registers
uint16_t ExtendedRead(uint16_t cs, uint16_t address, uint32_t& value)
uint16_t results;
uint16_t readFlags;
uint32_t timeout;
uint32_t currentTime;
// Write the address to the Extended Read Address register
results = PrimaryWrite(cs, 0x0A, address & 0xFFFF);
if (results != kNOERROR)
return results;
// Initiate the extended read
results = PrimaryWrite(cs, 0x0C, 0x8000);
return results;
timeout = millis() + 100L;
do // Wait for the read to be complete
results = PrimaryRead(cs, 0x0C, readFlags);
return results;
// Make sure the read is not taking too long
currentTime = millis();
if (timeout < currentTime)
return kEXTENDEDREADTIMEOUTERROR;
} while ((readFlags & 0x0001) != 0x0001);
// Read the 2 data registers
uint16_t addresses[] = {0x0E, 0x10};
uint16_t values[2];
uint16_t errors[2];
PrimaryRead(cs, addresses, values, errors, 2);
// Check all of the results of the reads
for (int index = 0; index < 2; ++index)
if (errors[index] != kNOERROR)
return errors[index];
// Combine them
value = ((uint32_t)values[0] << 16) + (uint32_t)values[1];
return results;
uint16_t ExtendedWrite(uint16_t cs, uint16_t address, uint32_t value)
uint16_t results;
uint16_t writeFlags;
uint32_t timeout;
uint16_t addresses[] = {0x02, 0x04, 0x06, 0x08};
uint16_t values[] = {address, (uint16_t)(value >> 16), (uint16_t)value, 0x8000};
uint16_t errors[4];
// Write into the extended address register
PrimaryWrite(cs, addresses, values, errors, 4);
// Check all of the results of the writes
for (int index = 0; index < 4; ++index)
// If writing to the EEPROM, generate the Program
// Pulses on Vcc
if ((address >= 0x300) && (address < 0x320))
// Send the Program Pulses
// Need hardware which this example does not have.
timeout = millis() + 100;
// Wait for the write to complete
do
results = PrimaryRead(cs, 0x08, writeFlags);
return results;
if (timeout < millis())
return kEXTENDEDWRITETIMEOUTERROR;
} while ((writeFlags & 0x0001) != 0x0001);
return results;
* SetProcessorStateToIdle
* Change the processor state to idle
* This is needed to write EEPROM, change ORATE or perform certain self tests
uint16_t SetProcessorStateToIdle(uint8_t cs)
uint16_t results;
uint16_t value;
// Write the enter idle state command into the control register
results = PrimaryWrite(cs, 0x1F, 0x8046);
if (results == kNOERROR)
delay(1);
// Read the status register to see if the processor is in the idle state
results = PrimaryRead(cs, 0x22, value);
if ((value & 0x00FF) != 0x0010)
return kUNABLETOCHANGEPROCESSORSTATE;
return results;
* SetProcessorStateToRun
* Change the processor state to run
* This is needed to process angles
uint16_t SetProcessorStateToRun(uint8_t cs)
uint16_t results;
uint16_t value;
results = PrimaryWrite(cs, 0x1F, 0xC046);
delay(1);
if ((value & 0x00FF) != 0x0011)
return results;
* CalculateParity
* From the 16 bit input, calculate the parity
bool CalculateParity(uint16_t input)
uint16_t count = 0;
// Count up the number of 1s in the input
for (int index = 0; index < 16; ++index)
if ((input & 1) == 1)
++count;
input >>= 1;
// return true if there is an odd number of 1s
return (count & 1) != 0;
* CalculateCRC
* Take the 16bit input and generate a 4bit CRC
* Polynomial = x^4 + x^1 + 1
* LFSR preset to all 1’s
uint8_t CalculateCRC(uint16_t input)
bool CRC0 = true;
bool CRC1 = true;
bool CRC2 = true;
bool CRC3 = true;
int i;
bool DoInvert;
uint16_t mask = 0x8000;
for (i = 0; i < 16; ++i)
DoInvert = ((input & mask) != 0) ^ CRC3; // XOR required?
CRC3 = CRC2;
CRC2 = CRC1;
CRC1 = CRC0 ^ DoInvert;
CRC0 = DoInvert;
mask >>= 1;
return (CRC3 ? 8U : 0U) + (CRC2 ? 4U : 0U) + (CRC1 ? 2U : 0U) + (CRC0 ? 1U : 0U);
And 12ms isn't fast enough? How fast would you like it to be? Since the scope trace seems to bounce off the bottom, I think that it is moving just as fast as the physical device moves.
What is the sensor chip you are using?
Morgan, to be honest I don't know the number I need. I do know the adc in the ecu, Siemens 80c515, and I also know when the I put the new sensor on the car it doesn't run very well. My thought was there is no harm in making the code as fast as possible.
The sensor is an alleged a1335
Hints to speed up a program on an 8 bit microprocessor with no multiply/divide hardware and no floating point hardware.
  1. Never use a variable larger than 8 bits(byte) if it can be avoided.
  2. Never use floating point variables if the math can be done in some type of integer.
  3. Multiply and divide should be coded using bit shifting and add and subtracts.
  4. Unwind any loops by creating stringy code that gives the same result as a loop.
  5. avoid calling functions if possible.
Paul
To my mind the first step in optimizing any program is to measure which part of the program is causing the bottleneck.
...R
There is a lot of harm in making it "as fast as possible."
Donald Knuth, one of the inventors of the C language said, "Premature optimization is the root of all evil."
I would investigate other sources of rough running first. Then come up with a specification for the speed required.
If the limitation is in the DAC output, you can switch from an i2c DAC to an SPI version like the MCP 4921.
EDIT:
dac.setNearestActualVoltage()
.setNearestActualVoltage() is not a library command I see in that library. Can you provide a reference?
vettett15:
It's best to work from actual Requirements rather than spending a lot of time solving a problem you may or may not have.
