Optimizing Code
Hello,
I am trying to make a Simon Says Memory Game and most of it is done. Now I am trying to speed up my program as I am using an ATTINY85 using a coin cell so ideally I want it running at 1MHz. The schematic I am using is this.
Can anyone make suggestions on how this program can be written more efficiently?
#define adc_disable() (ADCSRA &= ~(1<<ADEN))
const int pins[] = {0, 3, 4, 1};
const int pinsLens = 3;
const int ledPin = 2;
const int RandPin = 2;
const int RedPin = 1;
const int GreenPin = 3;
int ran;
int ans[8];
int in[8];
unsigned long timestart;
bool wait;
int buttonState[pinsLens + 1];
int lastButtonState[pinsLens + 1];
unsigned long lastDebounceTime[pinsLens + 1];
int reading[pinsLens + 1];
int i;
int j;
bool fail;
int PassFailpin;
unsigned long debounceDelay = 15;
int level = 3;
float DelayMulti = 3;
  randomSeed(analogRead(RandPin));
  adc_disable();
  startup();
  delay(DelayMulti * 100);
  startround();
  for (i = 0; i <= level; i++) {
    ran = random(0, (pinsLens + 1));
    ans[i] = ran;
    digitalWrite(pins[ran], LOW);
    pinMode(pins[ran], OUTPUT);
    delay(DelayMulti * 125);
    pinMode(pins[ran], INPUT_PULLUP);
  delay(DelayMulti * 300);
  for (i = 0; i <= pinsLens; i++) {
    pinMode(pins[i], INPUT_PULLUP);
  for (int i = 0;i <= pinsLens; i++) {
    buttonState[i] = HIGH;
    lastButtonState[i] = HIGH;
    lastDebounceTime[i] = 0;
  wait = true;
  timestart = millis();
  while (((millis() - timestart) <= 100000)) {
    for (j = 0; j <= level; j++) {
      wait = true;
      while (wait == true) {
          reading[i] = digitalRead(pins[i]);
          if (reading[i] != lastButtonState[i]) {
            lastDebounceTime[i] = millis();
          if ((millis() - lastDebounceTime[i]) > debounceDelay) {
            if (reading[i] != buttonState[i]) {
              buttonState[i] = reading[i];
              if (buttonState[i] == LOW) {
                in[j] = i;
                wait = false;
          lastButtonState[i] = reading[i];
  fail = false;
  for (i = 0; i < 8; i++) {
    if (in[i] != ans[i]) {
      fail = true;
  if (fail == false) {
    for (i = 0; i < 3; i++) {
    endround(GreenPin);
    if (level != 8) {
      level++;
  else if (fail == true) {
    endround(RedPin);
    level = 3;
void startup()
  for (i = 0; i < 4; i++) {
    digitalWrite(pins[i], LOW);
    pinMode(pins[i], OUTPUT);
    delay(DelayMulti * 75);
  for (i = 4; i >= 1; --i) {
    pinMode(pins[i - 1], INPUT_PULLUP);
    digitalWrite(pins[3 - i], LOW);
    pinMode(pins[3 - i], OUTPUT);
    delay(DelayMulti * 50);
void startround()
  for (i = 0; i < 9; i++) {
    ans[i] = 0;
    in[i] = 0;
  fail = false;
void endround(int PassFailpin){
      digitalWrite(PassFailpin, LOW);
      pinMode(PassFailpin, OUTPUT);
      pinMode(PassFailpin, INPUT_PULLUP);
      delay(PassFailpin * 50);
Never looked at a ATtiny but to my knowledge the below should also apply to the ATtiny
could be reduced to two instructions if the pins are on the same port. It’s called port manipulation and will be worth an investigation.
//Edit
Just looked at the datasheet and it only has one port so it should speed up your code.
